Overhead Console Removal
Old 05-11-17, 05:01 AM
warmdye
warmdye's Avatar
Default Overhead Console Removal
Can anyone provide some tips on how to remove the overhead console? I have a rattle that is driving me crazy. I would like to remove this and attempt to fix it.
Old 05-11-17, 06:18 AM
kcstunna82
kcstunna82's Avatar
You shouldn't even need any tools. Go to the very front plastic piece (closet to the windshield) pull down gently and work your way around. I just did this yesterday after hard wiring my radar detector.
Chaos236 (04-05-20)
Old 05-11-17, 08:48 AM
peasodos
peasodos's Avatar
Received 2,226 Likes on 1,450 Posts
Check if your rear view mirror is loose. Mine was very loose, just had to tightend the toric bolt on it.
Chaos236 (04-05-20)
Old 05-11-17, 08:53 AM
Davenlei
Davenlei's Avatar
Yea, it is scary to tug but it takes some force to get the tabs to release the unit. Give it a slow firm increase in pulling pressure on the side closest to the windshield and it should pop out.
The hard part is getting it back in. One of the sides has a hook type of clip if I recall right and you have to position it just right for it to lock back in or that one side will not go completely snug against the headliner as it was before. It took a few tries to get it to hook and stay snug.
There is not really much in there to rattle around. It is mostly pieces screwed into the panel, wires and empty space. I would do what peasodos recommended and check your mirror first.
Chaos236 (04-05-20)
Old 05-11-17, 03:04 PM
warmdye
warmdye's Avatar
Thanks for all the replys. When I push up on the corner of the console it stops making a noise. I think the noise results from friction with the headliner due to vibration. I'll check the mirror though.
Old 04-05-20, 12:29 AM
Michaelll
2nd gear
Michaelll's Avatar
did you ever fix the issue? have a loud rattle in the same area and was looking to fix it.
yusuke1923
CT 200h Model (2011-2017)
10-15-22 06:37 PM
Luscombe8A
05-12-18 12:22 PM
arnieosp
NX - 1st Gen (2015-2021)
01-19-18 10:58 AM
kcstunna82
01-16-18 12:03 PM
hahahaf
IS F (2008-2014)
04-18-14 04:38 AM
Quick Reply: Overhead Console Removal
