RPM going up when you brake while drive
Old 08-28-12, 08:23 AM
ryoohee
ryoohee's Avatar
Default RPM going up when you brake while drive
New GS owner, I noticed that
- RPM going up when you brake at the speed over 40 or while drive, not alway, just like engine brake when yo going to downhill experience? is it normal or ?
Appreciate to share your comments or experience.
Thanks
Old 08-28-12, 08:51 AM
jtrue28
jtrue28's Avatar
Your engine is downshifting...so yeah, it's normal for the RPMs to spike while braking.
Old 08-28-12, 09:39 AM
rominl
exclusive matchup
rominl's Avatar
this is especially the case if you are going downhill
Old 08-28-12, 03:28 PM
peteharvey
peteharvey's Avatar
Yes, during more sudden braking or sudden release of the throttle, the gearbox shifts to a lower gear, causing engine speed in rpm's to rise, for engine braking.
If we gently ease back off the throttle, the sensors know we are coasting, so there is no automatic downshift for engine braking; this is especially true is the car is also going downhills, because there are sensors that detect if the vehicle is going uphill or downhill.
Old 09-03-12, 07:37 AM
varcity64
varcity64's Avatar
i think i noticed this "issue" when driving in S+. when i started driving in the "normal" eco mode, it stopped.
Old 09-05-12, 12:19 PM
GSTONY
GSTONY's Avatar
yes its most noticeable in sport+ its normal i always rev match in my manual car. now every thing is automatic i still perfer doing it my self but its very helpful on the track
Old 09-05-12, 05:12 PM
Winson6628
Winson6628's Avatar
Its the feature of Sport +, designed for the more aggressive driving. Not an issue.
Old 10-17-18, 06:42 AM
vinniesabo
vinniesabo's Avatar
I am having the same issue lately. Jumps up to about 100-1100 RPM and then it dips down again to about 700. Also, if the heated or ventilated seat switch is in the off or the first of the 3 positions (2007 LS 460), RPMs are at about 500 instead of the normal 700-750
Old 10-17-18, 08:36 AM
UDel
UDel's Avatar
I noticed on my GS too some pretty rough shifting like when on cruise control on the highway and going down a incline, there is also a area near me I have always noticed some pretty rough shifting on previous cars and noticed it on my newer GS too, it is a pretty steep incline where you normally take your foot off the gas. This is normal. Your LS uses the air conditioner for the seats so the rpms would go up when you have it switched on, GS uses non AC air so it should not make any difference in rpms if it is on unless it is drawing a lot of extra power from the battery/alternator.
Old 10-22-18, 04:33 AM
vinniesabo
vinniesabo's Avatar
Update.. I changed the engine air filters and the RPM issue (spiking when coming to a stop) has gone away. I'm curious to see if changing the cabin air filter will fix the RPM issue related to the ventilated/heated seats. I will update in about a week, going on vacation.
Old 10-22-18, 09:02 AM
bclexus
bclexus's Avatar
Received 1,996 Likes on 1,418 Posts
Old 10-22-18, 11:26 AM
eddie420
eddie420's Avatar
Originally Posted by bclexus
^ This........
Teddyofind
GX - 2nd Gen (2010-2023)
02-01-13 09:45 AM
niteflite
10-13-10 03:53 AM
djjt
Performance
05-11-06 07:38 PM
TOPSPEED
04-29-04 06:21 AM
GlobeCLK
03-17-01 02:44 PM
Quick Reply: RPM going up when you brake while drive
