Cold area package/winter heater how exactly work?
Hello, my car have all the extras , including Cold area package/ winter heater , i am not sure how this thing exactly works?
i know some mercedess models have Heater which uses petrol or diesel you can pre set time and time and when you enter car its always warm in the winter?
I dont see only factory buttons, can someone tell me how i can make my car always warm and use this cold are package/ winter heater?
Also what this cold area package exactly includes if it includes heater how can be used or it doesnt include heater, it will be bad not to include heater..
High-intensity interior heater - thats the thing which i want to know how exactly operates can it be programmed if not can i make my car always warm when i start it , to receive hot air or its not possible i have no idea how this thing works.
The high intensity heater, per the manual, only works when the outside temp and engine coolant temp is less than a certain amount AND the heater temperature is set to HI.
I'm not sure it does much, because I attempted to use mine this morning but the vents still blew cold. Maybe a fuse has blown but I haven't checked.
How much time it needs to heat you up?
My car has this, it kinda works but it's not that strong. If you hold you hand over the vents the air comes out almost room temp rather then warm. It's really not much, but I guess it's something.
I think the temperature needs to be below 50 F before it starts working.
Useless is a good word for it.
The heaters are called "PTC" heaters in the manual and under the hood (fuses and etc). there are two relays that power two separate heater banks. The manual states the banks can either both be on or only 1, depending on how cold it is outside. The realys are controlled via a switched ground in the HVAC controller. The PTC heater is the "Heavy duty heater" part of the cold weather package and the hybrid models. You can verify this via the spare parts catalogues or in the repair manual for your specific car.
From the manual:
Blower switch: LO
Temperature set to HI
ECO drive mode off
Engine coolant temperature 64°C (147.2°F) or lower
Ambient temperature 10°C 50.0°F) or lower
Engine running
Also in the manual:
HINT:
• When all operation conditions are met, 2 quick heater assemblies are operated.
• The number of quick heater assemblies operated changes according to the engine coolant temperature.
If the resistance scaling is known for the ambient air temp, a bypass could be wired to trick the ECU and force the heaters to turn on. This would be great for defogging in the spring or late-summer/early-fall due to the dew and likelihood of fogged up windows.
From the manual:
Blower switch: LO
ECO drive mode off
Engine running
Also in the manual:
HINT:
bloodbean (11-11-22)
