Several Beeps When Unlocking
Old Jul 21, 2022 | 03:38 PM
maiahsdad's Avatar
maiahsdad
Originally Posted by jgscott
I'm talking about the little Dimple button on the top left of the drivers door outside handle. Are you hitting it any kinda way by mistake being you have a the car for a few without this problem?
I am familiar with this little button that will lock the doors. I've never known it to unlock though. At any rate, I don't use it.
Old Jul 21, 2022 | 05:13 PM
bclexus's Avatar
bclexus
@maiahsdad - Holding the driver's door handle unlocks only the driver's door and there will be 3 beeps heard exterior of the vehicle. This is supposed to happen!
For more than 3 beeps heard exterior of the vehicle when trying to use the key fob to unlock doors, try replacing the battery in your key fob. If that's not the problem it might be one or more of the actuators.
8 Beeps When Unlocking The Car Help Please
Old Jul 21, 2022 | 05:22 PM
maiahsdad's Avatar
maiahsdad
What happens you you unlock with the key fob remote? Only one solenoid click that happens in the door to unlock? Then if you key fob remote unlock, then pull to open the door what happens then?
It doesn't do it when I open the car with the keyfob. Only when using my hand on the door handle. The keyfob works perfectly.
Old Jul 21, 2022 | 06:14 PM
jgscott's Avatar
jgscott
Originally Posted by bclexus
@maiahsdad Try replacing the battery in your key fob. If that's not the problem it must be one or more of the actuators.
https://youtu.be/Hy6Pgij2nlw
That's a good guess. I would try what you said. The problem is he says it works fine when using the key fob. And also the actuator is trigging 5 times Not just beeping.
Hey one more though??? Op go to the Passenger door. Is it doing the same thing triggering 5 times???
Old Jul 21, 2022 | 06:22 PM
bclexus's Avatar
bclexus
Originally Posted by maiahsdad
When I approach my vehicle and unlock it by grabbing the door handle, it will unlock the vehicle but will sound several beeps. I can't find out why. Any ideas? There must be some issue.
Thanks for the input.
Old Jul 21, 2022 | 06:42 PM
jgscott's Avatar
jgscott
I looked that up also. Its in the Owners book too. But would this cover what he said which is - " It's like I grab the handle and it goes through the process of opening the doors like 5 times. So it beeps 5 times. Crazy."
Again if it was me I would try what you said. I think you are on to something!!!
Old Jul 21, 2022 | 06:47 PM
bclexus's Avatar
bclexus
The OP's original post says the car is beeping 3 times. In a later post he states the car is trying to unlock the door about 4 or 5 times. Who knows what he's doing or what he's experiencing! I certainly don't understand...
Old Jul 21, 2022 | 07:30 PM
jgscott's Avatar
jgscott
I know, that's why I told him to see if the passenger door was doing the same. Seems its unlocking with the actuator 5 times, and beeping 5 times. Lets see what he says about the pass door? Again I think you are on to something about the "switching the unlock function procedure".
Lets see what he says. And what happens when he does the switching procedure you recommended. b..... be patience.
Old Jul 23, 2022 | 10:44 AM
bclexus's Avatar
bclexus
@maiahsdad - Did you ever get it figured out? What needed to be done to fix it...or was it operating correctly all along?
Old Jul 24, 2022 | 02:57 PM
jgscott's Avatar
jgscott
Yes I want to know this too. This was very strange. I could see 5 beeps as a waring of misfunction or door not completely closed or something like that. But not it trying to unlock with the actuators going 5 times?
Old Jul 25, 2022 | 09:28 AM
2GR's Avatar
2GR
Do all the doors lock and unlock properly?
Friends '15 Camry did something similar and it turns out the Right Rear Door Lock Actuator was jamming/failing. The car would beep and lock/unlock several times as a warning that something failed.
Old Jul 25, 2022 | 11:37 AM
maiahsdad's Avatar
maiahsdad
Yes, no issues noticed with other door locks. I thought that once but haven't noticed anything. Or maybe it's so intermittent that I've not caught it. I mostly ride alone.
Old Jul 25, 2022 | 11:52 AM
bclexus's Avatar
bclexus
Oh well, I guess you don't want to share with us what the problem was or what needed to be done to fix it.
Old Jul 25, 2022 | 01:19 PM
maiahsdad's Avatar
maiahsdad
My issue is not fixed. The person asked if the doors would unlock independently. My issue is what I originally stated that it is.
Old Jun 29, 2023 | 08:34 PM
hdianbjdks's Avatar
hdianbjdks
1st Gear
Default Fix
Originally Posted by maiahsdad;[url=tel:11320757
11320757[/url]]When I approach my vehicle and unlock it by grabbing the door handle, it will unlock the vehicle but will sound several beeps. I can't find out why. Any ideas? There must be some issue.
I drained the car battery by leaving it on in accessory then jumping it with another car. Seems to have hard rebooted the car and the beeps are back to 1
