Paint Peeling on Driver’s side Mirror
The peeling mirror.
I used one of these kits on a number of spots on a car and with some areas it is almost invisible:
https://drcolorchip.com/touch-up-pai...mium-packages/
Or if you'd rather just use a spray can in a matching color, I have done that to good success. I don't remember what brand of can I used. You wouldn't have to remove the mirror if you didn't want to. Since the mirror is at a different angle and separated from the car, a slight difference in paint match won't be so noticable.
The peeling mirror.
The peeling mirror.
Get the oem factory painted mirror cover, perfect match, and will not peel off like that. Do not use Dr Color Chip for this it's $45 plus shipping and will look like crap over that much peeled paint, your beyond a chip here buddy. Rest of that paint will probably peel off over time.
First you have to remove the mirror/glass. To do this move the mirror all the way to the inside, so you can stick you hand behind it, then pull, do NOT put any pressure directly on the front glass/mirror itself, just on the back side. Pull hard, it will pop off. Once you remove the mirror/glass there are 5-6 screws to remove, then the rest of the mirror comes apart, including the outer cover.
You don't remove any door panels or interior trims to change this outer mirror cover.
https://www.clublexus.com/forums/gs-...light-led.html
