2016 GS 350 - Tag light out
Old Jun 10, 2022 | 11:02 AM
Joncone's Avatar
Joncone
2nd gear
Default 2016 GS 350 - Tag light out
Both tag lights are out on my car. The fact that these things are hard to get to leads me to believe this isn't a common problem and I'm not even seeing repair videos online.
Is it possible the lights themselves aren't bad but maybe a bad fuse? Thanks for any help.
Old Jun 10, 2022 | 11:12 AM
AJLex19's Avatar
AJLex19
@Joncone you might be the first with their license plate lights burning out on the 4GS - they are LED built into the circuit board as far as I remember (there isn't a bulb you can remove/switch). It could be a fuse i'm not sure (i'm leaning toward a failing LED though).
There is an aftermarket option to replace: https://store.ijdmtoy.com/products/o...32677628215399
Lexus OEM: https://www.mylparts.com/oem-parts/l...bly-8127053030
Here is a helpful write-up on replacing the bulb/housing with those aftermarket ones from iJDMToy: https://www.clublexus.com/forums/gs-...arket-led.html
Old Jun 10, 2022 | 12:14 PM
ItzFilyO's Avatar
ItzFilyO
Yeah, first time I heard this light went out. LEDs usually last a long time. Just get OEM since they're not that much anyway.
Old Jun 10, 2022 | 01:12 PM
703's Avatar
703
Unlikely two led lights go out at the same time. Check harness and fuse.
Old Jun 19, 2022 | 08:34 AM
Joncone's Avatar
Joncone
2nd gear
Follow up to this thread.
This is my wife's car that we have had a couple of years now and until she got pulled last week, we had no idea the license plate lights weren't working.
So I removed the trunk lining and found... The lights were unplugged. Why the previous owner did this, I can only guess but it's two plugs so no way it was done by accident.
Anyway now I know why I couldn't find YouTube videos for light replacement because it probably is never needed.
Old Jun 19, 2022 | 12:21 PM
703's Avatar
703
Yep. As I have guessed.
Was your car in an accident and the repairer forgot to plug the lights back in.
Old Jun 19, 2022 | 06:59 PM
bclexus's Avatar
bclexus
That was my first thought...
Chris350F
Oct 11, 2021 05:53 AM
Mike218
Jun 16, 2017 04:00 PM
cardboy008
GX - 1st Gen (2003-2009)
Jan 26, 2017 03:51 PM
jomomma160
12
Apr 5, 2011 09:14 AM
Brandicus
Jan 18, 2006 09:47 PM
