air conditioner
Old May 27, 2022 | 02:04 PM
stanton's Avatar
stanton
1st Gear
Default air conditioner
I recently placed a can of r134a refrigerant into my Lexus gs350 F sport, 2013 model
shortly afterwards, compressor started to make funny sounds and hot air coming out, instead of colder, it got worse.
I figured I overcharged it so I turned it off , waited about a month and when I turned on the AC, it started working again without any problems
I check pressure on the low port and it registered on the lower end of the GREEN markings (adequate charge)
After about 5 months, air conditioner not working again and there is an intermittent strange noise from compressor
Is it possible that compressor got ruined on that initial overcharge or what do you think? possible leak in system or something else?
Old May 27, 2022 | 04:47 PM
bclexus's Avatar
bclexus
@stanton - Why would you ever just decide for no reason at all to add refrigerant to a vehicle's A/C?
Refrigerant should never need to be added to any A/C - whether it is a vehicle, a residential central HVAC, a refrigerator, or a freezer. The refrigerant is in a 'closed-loop' system and should never leak or become low.
When was the last time you (or anyone you know) had to add refrigerant to a refrigerator or freezer? NEVER!
You should never (EVER) need to have a vehicle's A/C serviced - much less to add refrigerant.
I don't know what damage, if any, you may have caused your car's A/C, but your action was because of pure and simple thick-headedness (a.k.a. stupidity).
Old May 29, 2022 | 07:37 PM
703's Avatar
703
Yes if you emptied a can without checking pressure then you would have exceeded the pressure and can damage many things including value, compressor etc
revesalex
Jul 23, 2025 06:59 AM
xeus
Jun 27, 2017 03:47 AM
Rubin85
Sep 8, 2016 01:42 PM
LS430Lexus
Dec 5, 2012 11:23 AM
3dog
Apr 30, 2004 04:42 PM
