2014 headlight issue
Old May 23, 2022 | 08:50 PM
gabe4000's Avatar
gabe4000
2nd gear
Default 2014 headlight issue
so i picked up a 2014 lexus gs350 last week. everything sounded good. except. i forgot to check the headlight. also when i took the car to get wash, the sunroof started leaking a small amount. it looks like the sunroof doesnt completely shut from the inside. but when i look from outside it looks flush. and the second isse, my passenger side low beam was off. i took off the ballast. when i turn on the headlight it turned on and then dimmmed off wihtin a few sceonds. so i got a aftermarket ballast from ebay, installed it, the light stays on however its not near as bright as the driver side. Do you think the bulb is different than the driver side or is the ballast a cheap aftermarket quality?
Old May 24, 2022 | 01:04 AM
Charlie777's Avatar
Charlie777
Congrats on the new car. To rule out the ballast and/or bulb issue, swap from one side to the other to see if you get the same result. Even if the bulbs are actually the same, one may have just been replaced prior to you purchasing and thus will be brighter compared to how old the other bulb is.
Old May 24, 2022 | 04:03 PM
gabe4000's Avatar
gabe4000
2nd gear
thanks. it the bulb is dimmer on the other side it would be the bulb. but if the bulb is brighter on the other side then its the ballast, right?
Easyf
May 15, 2022 05:52 AM
EvanVanVan
May 10, 2022 09:01 AM
Zmon
Aug 11, 2021 03:34 PM
illini19
Jan 6, 2018 10:25 PM
CarKrayz
Aug 20, 2014 08:13 PM
