Reprogram Side View Mirrors ?
Recently I’ve noticed when I put my 2014 in reverse, the side view mirrors angle inwards and not down how they once did.
Does anyone know if there’s a procedure or setting to reset or reprogram the mirrors to angle down again?
With the shift lever in R, adjust the mirror angle at a desired position. The
adjusted angle will be memorized and the mirror will automatically tilt to the
memorized angle whenever the shift lever is shifted to R from next time.
The memorized downward tilt position of the mirror is linked to the normal position
(angle adjusted with the shift lever in other than R). Therefore, if the normal position
is changed after adjustment, the tilt position will also change.
When the normal position is changed, readjust the angle in reversing.
If you messed around with your side mirrors recently, just click the seat memory setting on the door panel. The position of the side mirrors are saved to the seat memory setting when you set it.
ThunderDmp
NX - 1st Gen (2015-2021)
Sep 15, 2021 05:55 AM
MPLexus301
Jul 16, 2009 11:30 PM
