Recirculation Flap
Old Aug 19, 2021 | 09:57 PM
RuninRoach's Avatar
RuninRoach
Default Recirculation Flap
I searched, found certain threads about this but couldn't find one specific to this issue.
When i checked behind the glovebox, i see that there are two flaps that open and close when you press the circulation button. I see that only one of them if fully closing and the other one is remaining half open; this was not the case before because going into tunnels was never an issue but now when i go into tunnels there is overwhelming smell of fumes and i get dizzy.
Anyone have a hack (other than breaking the automated open/close level and screwing them closed) that has worked, or is there an easy way to fix it other than the 2k replacement (remove dash, remove airbag, remove whole assembly, replace motor and mechanism)?
Old Aug 21, 2021 | 10:36 PM
RuninRoach's Avatar
RuninRoach
=( nobody...
Old Aug 22, 2021 | 04:23 AM
DiscoJango's Avatar
DiscoJango
i suppose until you find the fix, you will just have to turn the fans off when entering tunnels
Or somehow fix it permanently to be recirculated mode somehow
Old Aug 26, 2021 | 11:07 AM
cnc369's Avatar
cnc369
are you sure there's nothing jamming the other flap or blocking the flap from moving all the way to the closed position when you hit recirculation mode? sometimes debri can cause that to happen. if theres nothing blocking or jamming it when its closing then i would suspect the linkage or gear on the housing is bad because both those flap doors operate off the same actuator motor. if one's closing and not the other then you would need to see whats causing it to bind up.
Old Aug 27, 2021 | 06:55 AM
Cwang's Avatar
Cwang
Wasn't there a recall for this?
Old Sep 22, 2023 | 04:47 PM
Shiloson's Avatar
Shiloson
10th Gear
Hello everyone,
Any solution for this yet? I'm having thesame problem with my 4th gen GS350
Sportznuts
Jan 13, 2020 01:31 PM
ThomasH95
Oct 19, 2016 06:50 PM
Defratos
IS F (2008-2014)
16
Apr 27, 2014 12:55 AM
DJJJAMES
GX - 1st Gen (2003-2009)
Sep 16, 2008 08:25 PM
