Pre-Collision System Emblem
Old Aug 13, 2021 | 12:08 PM
mfaheem's Avatar
mfaheem
Default Pre-Collision System Emblem
So the other day something flew on the highway and hit my front L emblem and it cracked. It's still on the car but has a big crack in the middle. No PCS light turned on in the dash and the it works like before.
Anyone know what will it take to replace the PCS emblem ? Just based on some research this seems to be a very expensive fix as I can't use any other emblem.
Old Aug 13, 2021 | 12:36 PM
peasodos's Avatar
peasodos
Here is one on eBay for $250
https://www.ebay.com/itm/303908575825
If you take the plastic trim off in the engine bay above the front grill, you can remove the radar and get access to remove the emblem. Held on by 2 retaining washers and clips in at the bottom.
Old Aug 13, 2021 | 12:37 PM
mfaheem's Avatar
mfaheem
Great thanks !!!! So I just need to replace it with a PCS emblem. Will any recalibration etc be required ?
Old Aug 13, 2021 | 12:40 PM
peasodos's Avatar
peasodos
No calibrating or anything, the emblem is purely cosmetic, and any crack in the emblem has no effect on the PCS or Dynamic Radar Cruise Control.
Old Aug 13, 2021 | 12:41 PM
mfaheem's Avatar
mfaheem
Great thank you ! I'll go ahead and grab one PCS emblem off Ebay then
Old Aug 13, 2021 | 12:45 PM
peasodos's Avatar
peasodos
The one I linked looks mint and even the nubs the retaining washer attaches too is still intact. Most people end up breaking that taking the emblem off.
If you loose or break your retaining washer taking it off here are new ones:
https://www.ebay.com/itm/401899707836
You should be able to save the old ones even if it gets bent taking it off, just bend it back.
Old Aug 13, 2021 | 08:27 PM
eddie420's Avatar
eddie420
I probably have one lying around, actually I have two I think. I'm in NJ as well and can list it on the CL Market Place if you want to take a look.
Arpadf189
Oct 2, 2019 03:18 PM
gekae24
Jul 9, 2015 07:52 PM
Silver'04
Jan 1, 2013 12:25 PM
SDJZZ31
May 11, 2003 11:38 PM
