High beam led problem Lexus GS F
Hello everyone, I have a small problem with my Lex, namely the led road lamps do not turn on for me ... I replaced the headlight because it was cracked, I moved the computers and low beam lights work when I turn on the road lights during the day, instead of them the low beam turns on ... Techstream 0 bugs ... when I turn on checking and mixes with Techstream, they turn on and don't turn on normally ... What could be the cause of the problem?
I just looked up where Tarnow is, you're Polish like my wife.
I assume English is your 2nd language so I apologise but I'm not sure what the issue is.
Send me a message in Polish if you like, I can understand that and give an opinion. Epic car to have in Poland. I visited Krakow and my wife is from a town nesr Katowice.
okey it's in Polish
I bought a GSF from the USA, one right lamp was damaged, so I replaced the front set with our European asymmetric with control units number 0008 for the USA is 0007. The problem is that the US regions do not match the EU .... error of the lamps pops up and only one Russian solved this problem so I returned to the lamps from the USA after a little repair. However, now the high beam (long) lights do not work for me, when I start from the switch ("spider" that's what we call it), the long, passing lights don't work and the rest works. As I do the test in Techstream, I turn on the high beam lights and I force the program to work, but the indicator on the board with the meter, this blue to the lights, does not light up. It does not detect any error in Techstream and Launch x431 pro, the fuses are ok. As I assume on the European everything worked, only a lamp error pops up and one lamp turns on later than the other and goes out the same way, but turning on the high beam lights normally and the indicator light too lights up. I'm confused because I don't know what's going on something has changed ..? I have no idea how to bite it .. Greetings from Poland ..
about computers, i.e. the control units, I meant the black ones under the lamps in the US, it is only black and I changed it, in the EU there is an additional unit under the lamps to control the traffic lights.
I bought a GSF from the USA, one right lamp was damaged, so I replaced the front set with our European asymmetric with control units number 0008 for the USA is 0007. The problem is that the US regions do not match the EU .... error of the lamps pops up and only one Russian solved this problem so I returned to the lamps from the USA after a little repair. However, now the high beam (long) lights do not work for me, when I start from the switch ("spider" that's what we call it), the long, passing lights don't work and the rest works. As I do the test in Techstream, I turn on the high beam lights and I force the program to work, but the indicator on the board with the meter, this blue to the lights, does not light up. It does not detect any error in Techstream and Launch x431 pro, the fuses are ok. As I assume on the European everything worked, only a lamp error pops up and one lamp turns on later than the other and goes out the same way, but turning on the high beam lights normally and the indicator light too lights up. I'm confused because I don't know what's going on something has changed ..? I have no idea how to bite it .. Greetings from Poland ..about computers, i.e. the control units, I meant the black ones under the lamps in the US, it is only black and I changed it, in the EU there is an additional unit under the lamps to control the traffic lights.
W ktorum roku byl twoj samochud wyprodukowany i jaki jest to model?Czy swiatla na ktore wymieniles pasuja do twojego modelu czy sa od innego modelu?Czy Twoje oryginalne światła „euro” są fizycznie uszkodzone, czy po prostu nie działają?Mozliwe ze lampy zastępcze wymagają ustawienia przez komputer w USA. W tym wypadku moze to byc bardzo drogie. Moze bedzie warto spróbować naprawić orginalne światła, nawet jeśli musisz uzyc części ze świateł amerykańskich?
Światła z USA mam, to on było jedno pęknięte obudowa środek został cały zachowałem go, kupiłem w PL od europejczyka , lampy są one tak jak w usa ztriple led tylko na USA długie są na jednej diodzie led a na EU są na kilkunastu adaptacyjne. Z Eu lampami działało i długie i innne oświetlenie tylko wyskakiwał błąd oraz lampa jedna prawa nie gasła tylko się siwieciła dłużej i postanowiłem wrócić do lamp z USA z przetwornicami ECU z usa i tu nagle lampy nie działaja, tzn wsyzstko działa tylko światła długie nie działaja i automat też, jak zrobie test sprzetu i wymuszam włączenie z Programu diagnostycznego to się długie właczą ale tylko lampy, kontrolka na desce się nie włączy. Auto Lexus GSF z 2016 lampy obojętne z którgo będa roku tak mi sie wydaje ważane są przetworcice te jesfnostki sterujące bo są inne numery i pewnie elektronike bo do eu jeszcze jest jedostka sterująca światłami długimi
??? Gentlemen, do you have any ideas what could be wrong ??? or maybe it is possible to adapt back or restore the factory settings or something like that so that the front lamps work again, and exactly the long lights on the ECU 0007 from American lamps? because on the ecu with the EU 0008 region they work long, but the lamp error on the dashboard (drivers) pops up or possibly how to make this error of the front lamps not pop up ...?
… but it is cool to have different languages on CL.
here we also have some hits with these cars, such as me
