Auto leveling head lights
Old Jun 8, 2021 | 11:11 PM
Cal916's Avatar
Cal916
Default Auto leveling head lights
I had a 2013 base gs350 and the head lights move up and down at start up. Does anybody know if 2018 gs350 f sport does the same
Old Jun 9, 2021 | 12:07 AM
Cal916's Avatar
Cal916
Originally Posted by jhonalex21
Yes there is adjustment screws
no i mean when the 2013 car started up the headlights did it by it self. The light beam would go up and down at night
Old Jun 9, 2021 | 05:24 AM
byungkuk's Avatar
byungkuk
Your car needs to have the auto leveling so called adapted front lighting (AFS) capability/option for the light dance to happen on startup..
Old Jun 9, 2021 | 07:10 AM
Cobra611's Avatar
Cobra611
Yes, my '18 F Sport does the same thing, when I start the ignition and my lights are on. Probably do it when they're off, as well. But, I just haven't checked.
Old Jun 9, 2021 | 08:26 AM
IntrinoX's Avatar
IntrinoX
I think auto leveling is standard. AFS, where it swivels left/right is part of a package.
Old Jun 9, 2021 | 08:45 AM
AJLex19's Avatar
AJLex19
@itsraysgs agreed - I thought that all 4GS's come standard with auto-leveling which causes the headlights to move up/down on startup as part of a system "test" (my old 2001 GS430 had this feature). The AFS is a separate feature that is not standard (usually included in Lux or F-Sport package) that swivels the lamp left/right when turning.
Old Jun 9, 2021 | 10:06 AM
jgscott's Avatar
jgscott
I have the feature.
So if you do a up/down adjustment under the hood. Does it stay adjusted, or go back to one Factory preset position Auto?
Old Jun 9, 2021 | 10:32 AM
byungkuk's Avatar
byungkuk
Originally Posted by jgscott
I have the feature.
Mine stays in the adjusted position
Old Jun 9, 2021 | 12:59 PM
IntrinoX's Avatar
IntrinoX
I have the feature.
it will stay adjusted, but will continue to auto level if needed
Old Jun 9, 2021 | 02:30 PM
Cal916's Avatar
Cal916
My 2018 f sport doesnt do that and it has that feature.
Old Jun 9, 2021 | 03:38 PM
jgscott's Avatar
jgscott
Now I'm confused?
So if I adjust it up the cut off beam lets say 1/2 inch pointing it at a Wall? Will the Auto adjust it back to the 1/2 lower, or where I adjusted it 1/2 up and stay?
Old Jun 9, 2021 | 03:39 PM
ItzFilyO's Avatar
ItzFilyO
It should stay at the new position.
I'm pretty sure the Auto-Leveling (up and down) is standard on all 2013-2020 GS and the Adaptive (left and right) could be an option on the Triple-Beam headlights.
Those with the triple beams, do ur headlights go left and right? My 21 ES with triple beams does.
Old Jun 9, 2021 | 04:17 PM
jgscott's Avatar
jgscott
I will check tonight, but I thought mine appeared to go around like 360 degrees. Then set.
Old Jun 9, 2021 | 07:27 PM
byungkuk's Avatar
byungkuk
yes it goes up and down but also goes side to side at the same time
Old Jun 9, 2021 | 10:56 PM
IntrinoX's Avatar
IntrinoX
If you adjust your level manually, then auto level will be based off of what you adjusted.
It will not go back to the original level.
