Red wire, Blue wire outside mirror replacement
Old May 24, 2021 | 06:47 PM
MX73's Avatar
MX73
Default Red wire, Blue wire outside mirror replacement
Ugh. I crack my outside mirror when replacing the mirror housing. Is there a difference between the red wire mirror and the blue wire mirror? I'm looking for a used glass on ebay but some sellers are saying the blue wire mirror won't work if you have a red wire mirror. I don't see the difference between the two. They both have the BSM light, dim, and heat.
Also, would the glass from the IS, ES, LS work since they pretty much have the same housing?
Old May 26, 2021 | 09:40 PM
peasodos's Avatar
peasodos
I couldn't find the one with the exact wires so what I did was swap the BSM led and circuit from my broken side mirror onto the new one and that did the trick.
You have to take apart the side mirror. Practice on the broken one first, the plastic is just clipped together. Obviously just try and see if the one you bought works first, if you get the BSM light on the dash you have to do what I did.
Old May 27, 2021 | 12:18 PM
MX73's Avatar
MX73
Thanks @peasodos !
Old Mar 25, 2022 | 02:16 PM
Charlie777's Avatar
Charlie777
I’m now in the same boat, cracked drivers side mirror on my 2013 with BSM and heated. I also see that sellers specify red or blue wiring. The back of my mirror wires are brown and grey and so far I haven’t seen any with this color unfortunately. To confirm, it doesn’t matter the colors of the wires, I can just transfer the wiring and led from my old mirror to the new one? @peasodos
Old Jul 17, 2022 | 12:02 PM
azfj60's Avatar
azfj60
If you're looking to install a dash cam using the OEM rear view mirror power, this company makes some USB taps that are worth the money, I think. Pull off the cover, and verify the connector for you have before ordering.
https://dongar.tech/products/10pin-type-b-lexus-toyota
Old Jul 17, 2022 | 12:12 PM
MX73's Avatar
MX73
This tread is talking about the outside mirror. Not the interior rear view mirror.
cosxp
Sep 10, 2024 03:11 PM
My3gs350
Sep 13, 2018 10:12 AM
costanza
Apr 18, 2013 10:01 AM
booramey
Oct 20, 2012 11:34 AM
