Need advice on 20 inch squared setup
Old Apr 12, 2021 | 05:15 AM
Kingmatt24's Avatar
Kingmatt24
Default Need advice on 20 inch squared setup
I have a 2013 base AWD on factory 18x8 wheels +45 offset sitting on 235/45/18 all season tires on all 4 corners. I'm looking for a squared setup and found some aftermarket wheels. They have 2 options, 20x9 +38mm and 20x9 +30mm. Which would be the better choice? Also, I'm not sure what tire size to go with. I don't want to deal with any rubbing or having to roll/pull any fenders because I plan on lowering on BC coilovers down the road for a nice, flush fitment. So I kind of want the widest/tallest I can get without having issues for when I'm ready to lower it
Old Apr 12, 2021 | 08:45 AM
Kingmatt24's Avatar
Kingmatt24
I did some more searching and there's another set of wheels I like even more since they're wider and cheaper. They're 20x10 +38mm. They also have 20x10 +35 and +40 options but they're on backorder. Which offset would work best? I'm thinking of going 245/35/20 all around with +38 offset, would this work? It's the front I'm concerned about because I would still lower it eventually
Old Apr 12, 2021 | 07:07 PM
kietlander's Avatar
kietlander
x10 +25 will not without fender mods, the 245 tire will be right on the fender liner. Here is a 20x10 +40 , he had to run 12mm spacers and extended studs up front and run 235 tires. https://www.clublexus.com/forums/gs-...-complete.html
Old Apr 12, 2021 | 07:31 PM
Kingmatt24's Avatar
Kingmatt24
thank you. I’ll go with the 20x9 +38 to
try to avoid issues. What tire size do you think I should go with? Would 245/35/20 work?
Old Apr 13, 2021 | 06:24 AM
Kingmatt24's Avatar
Kingmatt24
I think I'm going to compromise and get the 20x10 wheels in a 20x8.5 +35 size instead when they're back in stock. I'm assuming a 245/35/20 all around would work with that setup?
TheCarGuy1
May 8, 2020 01:29 PM
MyisFly
IS F (2008-2014)
Feb 27, 2014 10:41 AM
ChiLexus10
Dec 9, 2013 10:38 PM
uenvyflac
Apr 28, 2006 12:15 PM
nysupraman
Wheels, Tires & Brakes Forum
Jan 13, 2005 09:13 PM
