Changing Tires on AWD
Old Oct 20, 2020 | 05:57 AM
Neophyte2b's Avatar
Neophyte2b
Default Changing Tires on AWD
Do I need to change all four tires at once on an AWD, or can I just change two?
Old Oct 20, 2020 | 07:53 AM
NJLEXES's Avatar
NJLEXES
That's a little too vague of a question. How many miles on the tires and what condition/tread depth do they all have.
Old Oct 20, 2020 | 08:54 AM
Neophyte2b's Avatar
Neophyte2b
I went in for a state inspection, and they said that the front tire tread was too thin. The rear tires were okay.
Old Oct 20, 2020 | 09:04 AM
praetor's Avatar
praetor
May as well do all 4. You're not saving much and are risking performance issues, braking and handling issues.
Old Oct 20, 2020 | 09:30 AM
Neophyte2b's Avatar
Neophyte2b
On a related note, do I need to do an alignment when I change the tires?
Old Oct 20, 2020 | 09:35 AM
CAKETOWN's Avatar
CAKETOWN
Usually not required if your wear has been even, if there was any unusual wear definitely get an alignment.
Old Oct 20, 2020 | 09:37 AM
Neophyte2b's Avatar
Neophyte2b
So, if I change all four, but my previous tires don't have uneven wear, then no need for an alignment? Just confirming. Thanks.
Old Oct 20, 2020 | 10:16 AM
Neophyte2b's Avatar
Neophyte2b
Is this a sign of uneven wear that would require an alignment, or is this just a bad tire?
Old Oct 20, 2020 | 10:28 AM
Final4GS's Avatar
Final4GS
Are your tires stretched and car lowered?
Inner tire wear generally caused by negative toe and camber.
If true, then you need an alignment.
Old Oct 20, 2020 | 10:40 AM
Neophyte2b's Avatar
Neophyte2b
No, the car is stock. Thanks for the help. An alignment, then, plus four tires. Yeesh, this inspection is turning out to be way more expensive than I had anticipated.
Just curious - my car drives straight as an arrow. Isn't that a sign of a good alignment?
Old Oct 20, 2020 | 10:45 AM
charley95's Avatar
charley95
How often do you rotate tires?
Old Oct 20, 2020 | 10:49 AM
Neophyte2b's Avatar
Neophyte2b
Does the AWD have a staggered setup? If so, I've been told that I shouldn't rotate the tires.
Old Oct 20, 2020 | 10:51 AM
praetor's Avatar
praetor
Staggered is only with RWD models. AWD have the same tires front and back.
Rotate them once a year for max life. I'm often too lazy to do that though
Old Oct 20, 2020 | 10:53 AM
charley95's Avatar
charley95
No, you were told wrong. RWD's are staggered and AWD's all match. You'll need to rotate every 5-10k miles to even out tread wear.
Old Oct 20, 2020 | 11:21 AM
Final4GS's Avatar
Final4GS
RWD F Sport are staggered 235 front 265 rear while AWD F Sport, AWD, RWD Base are 235 all around.
Some people size up to 245 to get more options for tires as there aren't as many tires for 235 than there are for 245.
Good rule of thumb, rotate tires when you do an oil change I can admit I was lazy in doing this on my '02 GS430 that was on coilovers but I guess I shouldn't be lazy on my '16 GS350 Lux that's stock height (for now).
