Side mirror motor fix
Old Sep 23, 2024 | 11:03 AM
  #31
shenry500's Avatar
shenry500
Originally Posted by GSonMoon
It failed on me today so i wanna give this a shot. Did you remove the glass mirror? To spray the contact cleaner?
Yes. You will need to take it apart as detailed above and have the small motor in your hand before spraying it.
Old Aug 24, 2025 | 04:20 PM
  #32
jonathancl's Avatar
jonathancl
My 2013 passenger mirror stopped up-and-downing. Web search was no help, and here is the complete answer. I love this place.
Full replacement motor part is fc140se8z550, which is a direct replacement including the correct gear. There are some on amazon for $15.
I could not get the motor apart: those little tabs are tiny and tough. But I was able to get it working again by cleaning the motor and running it on a 9v for a little while to burn the lube off the brushes. There were visible arcs and rough operation at first, and after a few minutes, the arcs ceased, and the motor ran smoothly. These little motors run so little and so seldom. The solution to successfully long running operation may be to exercise them on occasion: run the mirrors through their full range of motion to run the motors a bit.
marty99
Jul 16, 2023 07:14 AM
new2lexus2
Sep 1, 2022 08:12 AM
David55
Sep 11, 2017 07:47 AM
ProjektSON
Apr 26, 2017 07:13 AM
Ontario
Jul 24, 2011 05:52 AM
