Hide switch in coin box
Old Jul 22, 2020 | 11:55 PM
Neophyte2b's Avatar
Neophyte2b
Default Hide switch in coin box
What's the best way to access the coin box to hide a switch for fog lights?
Thanks.
Old Jul 23, 2020 | 02:23 AM
Cwang's Avatar
Cwang
Mmm....not a great place for a switch, moving parts are always dangerous! Why not do what I did and put the switch where the nightvision switch goes? What MY?
Old Jul 23, 2020 | 08:34 AM
Neophyte2b's Avatar
Neophyte2b
MY2013 F-sport.
I'm using a non-OEM rocker switch. Will that make a difference?
Old Jul 23, 2020 | 09:22 AM
anish3232's Avatar
anish3232
Originally Posted by Neophyte2b
MY2013 F-sport.
The depth of the switch can be an issue. I put a switch to turn the amp off to my sub. It’s perfectly hidden and no one would know it’s there.
Old Jul 23, 2020 | 09:26 AM
Neophyte2b's Avatar
Neophyte2b
Where did you hide the switch, and how did you do it?
Old Jul 23, 2020 | 10:15 AM
anish3232's Avatar
anish3232
I had to remove the lower half of the dash board mainly the part by your knees and below. The coin box is attached to it so once I had it removed I drilled a circular hole so my switch would slide in. Here are some pics. First pic has the coin door closed with bass ****. Pic 2 and 3 is the switch to turn the aftermarket amp on and off. The switch has a small red led light when it’s turned on. Gives out a decent amount of light at night so that’s a plus.
Old Jul 23, 2020 | 10:17 AM
anish3232's Avatar
anish3232
I would get a hold of 3-4 switches that aren’t very deep bc there isn’t much clearance around the coin holder. It would be best to remove the lower dash and evaluate before drilling holes.
Old Jul 23, 2020 | 11:01 AM
Neophyte2b's Avatar
Neophyte2b
How did you remove the coin holder itself? Also, did you drill the hole at the top as opposed to the past that is right in front of you when you're looking at it? Thanks
Old Jul 23, 2020 | 11:25 AM
anish3232's Avatar
anish3232
I did not remove the coin holder. It was still attached to the lower dash when I removed it. I just drilled a hole on the top part of it. I used the top of the coin holder as the switch would be stationary. If it was attached to any other part of the coin holder the wires would be moving each time you open and close it.
Old Jul 23, 2020 | 01:29 PM
Neophyte2b's Avatar
Neophyte2b
Thanks. After I remove the side air vent and the plastic piece by the footwell, do I just pull on the plastic piece that includes the coin holder? Will it just come out with a tug? I'm asking because I tried that last night and it didn't seem to want to pop off.
Old Jul 23, 2020 | 04:14 PM
anish3232's Avatar
anish3232
There’s a 10mm bolt or two. Check the forums for a how to dissemble the dash and it should be pretty easy. Be careful with the airbag. I did not remove it during my install.
Old Jul 23, 2020 | 04:33 PM
eddie420's Avatar
eddie420
Second post, a few pictures down you can see how to remove that area: https://www.clublexus.com/forums/gs-...l#post10329371
Old Jul 23, 2020 | 06:02 PM
jtrue28's Avatar
jtrue28
What is that **** to the right of the coin holder?
Old Jul 23, 2020 | 07:16 PM
anish3232's Avatar
anish3232
Gain control for the sub I have in the trunk.
D3V3LOP3R
Suspension and Brakes
Mar 23, 2025 01:05 PM
Billnoelr
Jan 9, 2022 01:26 PM
Mejay713
Oct 3, 2018 01:23 PM
KahnBB6
Aug 20, 2011 06:54 PM
