4GS 2016+ questions
That's about all I can think of right now. Oh, and the steering wheel is different now.
"The GS's underbody aerodynamics have been improved by positioning the bottom edge of the front bumper 10mm further forward, to adjust the volume of air passing under the floor. Lexus has paid strict attention to optimising body strength and rigidity in the GS to achieve high levels of crashworthiness and durability, as well as lower interior noise levels.A highly rigid body also provides a stable platform for the suspension, while optimising handling stability and ride comfort. The 2016 year model GS Line body has been further refined, with new design features and greater use of key body manufacturing techniques.
The new GS body has an additional 188 points of spot-welding to the frame to optimise panel-coupling rigidity - focusing on the cowl, the junction of the rocker panels and B pillar, and the rear shelf. Coupling panel rigidity has been further boosted by increased use of body adhesive.
The new GS body has an additional 22.5 metres of body adhesive. The rear of the cabin has more laser welding points, and the door surrounds have an additional 132 laser-screw welding points compared with the current body.
A performance damper has been adopted between the left and right front number two members on GS 200t EX and GS 350 F-Sport, to reduce vibration and increase stability. The GS Line upper-cowl area has been further refined by adding sound-absorbing material to enhance cabin quietness."
2016+ get...
- LED headlights as standard whereas they were Bi-Xenons before
- "Intelligent High Beams" - I don't think these were previously available
- Puddle lamps on all 4 doors are LED - they were incandescent before
- Full LED taillights as standard - they are super detailed & three-dimensional with super bright turn signals, reverse lights, & have a clear housing. Big upgrade, in my opinion. Similar to the all-new ES' taillights, but even nicer and of higher quality.
- New instrument cluster screen with additional functionality. 2015 and older doesn't give you much. You get range to empty, outside temp & tire pressure - not much else. 2016+ you get displays for G-Force, audio, navigation, Adaptive Cruise/Lane Keep/Steering Assist, and so on.
- Remote Touch controller updates. There's now a physical back button and additional select/Enter buttons on the sides of the controller. The palm rest is now "leather" wrapped with stitching and the little puck you actually move around gets lined in chrome. 2015 and older have all-black hard plastic palm rest and controller.
- Newer generation navigation software/display that is more in line with more recent Lexus systems (but is not the newest). This allows full-screen map mode which wasn't available previously. New system gets enhanced voice recognition. There are also other slight updates, such as the navigation system automatically re-routing you when it detects traffic whereas the 2015 and older has to ask for permission to do this.
- Updated window switches with chrome trim as opposed to the all black plastic ones you'll find in 2015 and older GS. Slight change but much more premium looking and feeling, similar (if not the same) as the ones in the new LS and LC (but not new ES - ES has all black plastic ones like older GS)
- Lexus Safety System+ (Pre-Collision System with pedestrian detection, Lane Departure Alert with Steering Assist, Lane Keep Assist, Vehicle Sway Warning, Intelligent High Beams, All-Speed Dynamic Radar Cruise Control with stop & go) - optional on 2016, standard 2017+
- Standard Blind Spot Monitoring with Rear Cross Traffic Alert (which means power-folding mirrors became standard as these two were linked - had to get one to get the other previously)
- New clock design & clock is now GPS linked and updates automatically. 2015 and older had 2 little buttons near the face of the clock used to adjust the minute and hour.
- New center air vent design. The updated ones have more slats, the older ones had single-slats. The newer vents also feel more refined to adjust. They're smoother and more fluid whereas the older ones were notchy and cheap feeling. The outboard air vents were also updated as was the silver trim that surrounds them.
- New A/C temperature displays are higher resolution and are now animated like you'll find on the new LS or LC. 2015 and older had calculator-style displays with no animations.
- New rear seat ceiling lighting (now centrally mounted)
- New shift ****
- New steering wheel
- New metal door handles. They were plastic previously.
- Brake Hold
- Updated "frameless" rear-view mirror
- New seat upholstery design & new side stitching pattern
- Ambient lighting color changed from "silky white" to "warm white"
- The double wishbone front suspension & multi-link rear suspension get new coil spring calibration
- Conventional and AVS dampers have been optimized to improve response
- Front stabiliser bar shape and characteristics have been refined
A big upgrade that goes nearly completely unnoticed is what @mkmckinley posted:
Last edited by signdetres; Jan 29, 2020 at 12:02 PM. Reason: Added a few more features that I missed
