2014 GS350 Bluetooth failure
Old Sep 25, 2019 | 12:43 PM
Flyrod's Avatar
Flyrod
Default 2014 GS350 Bluetooth failure
Hello all,
My first forum post. I recently traded my 99 GS300 which I had owned for 14 years for my new-to-me gen 4 2014 GS350, Meteor Blue RWD with less than 45K miles on it. I discovered the the Bluetooth is off (showing "no connect") and the control panel in the menu is grayed out not allowing it to be turned on. An hour of labor at the dealership determined that it's the radio head unit that's at fault. The dealer from whom I purchased the car is willing to pay for the replacement of the head unit but he's understandably choking on the nearly $3000 estimate. This is a Canadian car with navigation and the radio head unit has a number on it - P10638. I have found a US model head unit but the number Is P10642. I can get that one for about $400 but have concerns about compatibility with the rest of the electronics.
Does anyone have any experience with such an issue? What was the resolution? Is it necessary to have a code to unlock the radio head units or are they compatible with other VINs without complex handshakes? Any help is appreciated. I was really looking forward to Bluetooth both for the phone and my tunes.
Thanks for any and all input.
Rod
Old Sep 25, 2019 | 01:15 PM
jonathancl's Avatar
jonathancl
Here's my thread on radio compatibility that may help you.
I did not note the front panel Pxxxxx numbers, but I noted the part numbers.
P10642 appears to be 86804-30040, which is not listed in my thread but seems to be a later version of 86130-30B10, which is listed.
Old Sep 25, 2019 | 04:39 PM
Flyrod's Avatar
Flyrod
Default Bluetooth won't connect
Thanks, very helpful. I may take a chance on the eBay unit. I'm reading into your thread a bit but it appears there is no code required to handshake with the car. I'm assuming if the connectors are the same and the faceplate is the same, it should work. I'm guessing main difference may be that the temp will show in Fahrenheit rather than Celsius as it does now. I'm old enough to relate to both so that doesn't matter. I'm also hoping Nav or no-Nav doesn't matter...
Thanks again for the thread info.
Rod
Old Sep 25, 2019 | 04:46 PM
bclexus's Avatar
bclexus
Flyrod - Is it common for people living in border states near Canada to purchase vehicles that were made specifically for, and distined to, the country of Canada?
Old Sep 26, 2019 | 02:28 PM
Flyrod's Avatar
Flyrod
I'm not really sure but there are restrictions on what can be imported to the US from Canada and what can't. If you are moving to Canada, you can bring your car with you as long as it has daytime running lights and a metric speedo scale and possibly some other minor mods. I live in Canada and when the Canadian:US dollars were closer, I bought a couple vehicles in the US and imported them to Canada. Lots of rules but not complicated and with all ducks in a row, it was painless. With the Canadian dollar worth about $0.75 US, that's a non starter. I know there are dealers here who buy up pickups and other used cars in demand and use a broker to ship them to the states - they seem to make money on it but it creates a shortage of used units here.
I'm about an hour from the US border at Port Huron, MI so often buy parts and accessories online and ship them to save brokerage fees.
05ls430518
Apr 9, 2018 06:53 PM
ta1drman
Apr 1, 2017 07:07 PM
Coleroad
Jan 30, 2016 05:58 PM
zazzn
Aug 28, 2015 04:24 PM
Jodwin
Oct 7, 2014 12:19 PM
