Serpentine belt change
Old Aug 27, 2019 | 02:33 PM
Zsikd's Avatar
Zsikd
Default Serpentine belt change
Has anyone changed their serpentine belt with something other than OEM parts?
Debating if I should go with OEM (found it on eBay for cheap from a Lexus dealer) but I need two idler pulleys... any recommendations? Thanks
Old Aug 30, 2019 | 05:49 AM
shrinkwrap's Avatar
shrinkwrap
Related to this, what mileage interval is best to change the S-belt?
Old Aug 30, 2019 | 06:55 AM
jonathancl's Avatar
jonathancl
I always found aftermarket belts squeaked quickly, felt like I was always changing them in my 2GS.
I never changed a belt before it started squeaking.
Old Aug 30, 2019 | 07:03 AM
Zsikd's Avatar
Zsikd
Mind only squeaks when the car is left outside overnight and not in the garage on a cold start... just ordered a OEM belt from bell Lexus on eBay. I wouldn’t replace it unless it squeak!
Old Aug 30, 2019 | 07:25 AM
ItzFilyO's Avatar
ItzFilyO
Replacing this should be easy on the 4GS right? There's a ton of space in the engine bay.
Old Aug 30, 2019 | 10:03 AM
AJLex19's Avatar
AJLex19
It was easy (had my personal mechanic do it for me and took him 10min). I bought an OEM serpentine belt for around $60 from mylparts.com. Mine had to be changed at 53k miles on my '13 as it was making an annoying chirping noise whenever idling and it was below 50 degrees out.
Old Aug 30, 2019 | 10:32 AM
bclexus's Avatar
bclexus
Why would you even consider installing an aftermarket serpentine belt in lieu of an OE belt - what could possibly be the advantage or benefit? I can't imagine the belt's cost would be a consideration.
What makes you think you need two idler pulleys? Are you considering aftermarket for that too?
Old Aug 30, 2019 | 12:02 PM
Zsikd's Avatar
Zsikd
Replacing it should definitely be easy on a 4GS. There's plenty of room considering that there's plenty of room to work with, as you said! Not a big job at all.
Old Aug 30, 2019 | 12:07 PM
Zsikd's Avatar
Zsikd
Awesome! Yeah, mine only squeaks if the car is left outside of the garage overnight. Since winter is coming around in MI, rather just replace it. Overall, a cheap job with OEM parts. I was just wondering if anyone has used aftermarket and their luck with it.
I found a deal on eBay with two Koyo pulleys + a Dayco serpentine belt for $68 approximately. One OEM v-belt from Lexus cost about $60, excluding the pulleys. A trusted mechanic I've been using for years recommended replacing the pulleys since they eventually go bad after replacement of a new belt. I ordered two Koyo pulleys and OEM belt off eBay for $100 altogether, which isn't bad. Koyo is usually what Japanese auto-manufacturers use anyways.
MikeFig82
Apr 11, 2019 01:41 PM
stech
Apr 1, 2015 06:45 AM
moat
25
Feb 15, 2012 06:29 PM
RI-Lex
Aug 13, 2008 09:10 AM
spyder357
Jan 24, 2006 02:40 PM
