Will these fit?
Old May 14, 2019 | 06:35 PM
gsfwin's Avatar
gsfwin
Default Will these fit?
I'm looking to get some wheels with these offsets. 19x9.5+20 19x10.5+14 with these
tires 235/35/19 245/35/19. Will they fit without rolling them, camber adjustment etc?
Old May 15, 2019 | 02:55 AM
bigblack06's Avatar
bigblack06
Depends on how low you will be but that offset seems like it will stick out you will def need a camber adjustment.
Old May 15, 2019 | 04:55 AM
SNiiP3R's Avatar
SNiiP3R
That’s an aggressive fitment. If you are going to lower the car, then some fender work, stretched tires and lot’s of negative camber will require.
Old May 15, 2019 | 10:24 AM
dphu626's Avatar
dphu626
You might have wheel poke. You will definitely need camber and fender adjustment if you plan to lower your car. Springs you might get away with not doing any adjustments, but springs aren't long term.
Old May 15, 2019 | 07:09 PM
gsfwin's Avatar
gsfwin
I am planning to lower the car on coils to about 1 finger gap. Im going for the tucked look and trying to avoid the fender work camber adjustment etc. I'm also looking at 19x9 50 and 19x10 41. These are gsf/rcf wheels specs. Would these work better? Or do a square setup instead? Thanks for all the feedback.
Old May 16, 2019 | 03:30 AM
bigblack06's Avatar
bigblack06
Yes these would work.
Old May 16, 2019 | 04:43 PM
PilotX's Avatar
PilotX
I have 20x9+32 in the front and 20x1.5+45 in the back on 247/275-30s. I needed camber arms for the drop, no rubbing no rolling.
Old May 17, 2019 | 11:20 AM
Blaque Diamond Wheels's Avatar
Former Sponsor
Those offsets are super aggressive and will need fender mods to fit without issues.
Old May 17, 2019 | 03:27 PM
gsfwin's Avatar
gsfwin
What's your camber in the rear?
Old May 17, 2019 | 03:35 PM
PilotX's Avatar
PilotX
Pretty good. They were sticking out pretty good in the rear before.
Spamboi
Aug 5, 2015 07:05 AM
jorgie523
Mar 24, 2014 09:45 AM
UGJZZ31
Suspension and Brakes
Apr 3, 2013 06:23 PM
AkureiKami
Aug 11, 2012 02:40 PM
RidinLow
Jan 30, 2009 08:00 PM
