GROM VL2 installed
Old Jun 15, 2019 | 01:36 PM
  #346
HUSKERnKS's Avatar
HUSKERnKS
Based on a comment above about a professional install, today I took my glovebox out, removed the GPS unit (silver box) and placed the Grom GPS puck on top of the duct work. In my testing it worked perfectly. 3m taped it, ZIP tied it, and reinstalled everything. So far, working like a charm with no outside signs that a system has been installed.
Worth a try if you don’t like the puck, or if like me you have had a couple broken windshields lately and were apprehensive about taping it down. :-)
Old Jun 15, 2019 | 06:03 PM
  #347
bob256k's Avatar
bob256k
Nice! I kinda overdid it when I installed mine. I extended the gps cable all the way to the back of the car, pulled the cable thru the trunk and mounted it on the back window....
Old Jun 21, 2019 | 06:19 AM
  #348
rj4510's Avatar
rj4510
Is the puck sitting under metal? Any difference in GPS lock that you can tell?
Old Jun 21, 2019 | 08:47 AM
  #349
HUSKERnKS's Avatar
HUSKERnKS
Not under metal. There is a bit above it from the speaker bracket. It is above the venting system.
It acquires pretty fast. I drove 3.5 hours through heavily wooded areas yesterday and never lost signal.
Old Jun 21, 2019 | 10:22 AM
  #350
c2fordy5's Avatar
c2fordy5
You didn’t happen to take pictures, no?
Old Jun 21, 2019 | 01:01 PM
  #351
HUSKERnKS's Avatar
HUSKERnKS
I didn't. I should have. Glove came out. Removed GPS box. You will see the duct work over by the right speaker. I put it on top of that.
Old Jun 22, 2019 | 10:39 PM
  #352
YaMomma's Avatar
YaMomma
I mounted mine to the front window, it looks like a stock sensor.
Old Jun 23, 2019 | 05:54 AM
  #353
HUSKERnKS's Avatar
HUSKERnKS
Nicely done
Old Jul 10, 2019 | 05:17 PM
  #354
HUSKERnKS's Avatar
HUSKERnKS
Noticed a new software version today 2.3.0.0. Any take it yet?
Old Jul 10, 2019 | 05:37 PM
  #355
jdpdata's Avatar
jdpdata
Finally a software update! I haven't seen an update for last several weeks. Grom did say they will fix DPI setting for Android Auto so font is not so huge, hope this is it. I'll update when I get a chance and report back.
edit: updated to latest 2.3.0.0. I don't see anything different. AA still have huge interface, they didn't change the DPI yet.
Old Jul 12, 2019 | 11:19 AM
  #356
c2fordy5's Avatar
c2fordy5
Updated as well. The only difference I saw was the number of icons on the home screen went from 8 to 10. @HUSKERnKS my map button doesn't work on the Android side anymore. Is that the same case for you? I've been using CarPlay a whole lot more since updating to iOS13. Not really a big deal for me but something I've noticed.
Old Jul 12, 2019 | 02:39 PM
  #357
HUSKERnKS's Avatar
HUSKERnKS
My Map button doesn’t work even on 2.2.0.0
Which version did you update to? I checked again today and noticed it is now 2.5.0.0
Old Jul 12, 2019 | 02:57 PM
  #358
c2fordy5's Avatar
c2fordy5
Yeah, mine stopped working since 2.2.0.0 also. I thought I’d be fixed on 2.3.0.0 but it didn’t. I haven’t checked to see 2.5.0.0 yet. At least the issue is consistent with our model
Old Jul 12, 2019 | 03:06 PM
  #359
HUSKERnKS's Avatar
HUSKERnKS
I will try 2.5.0.0 later on and let you know. I am using a mix of Android and CarPlay to test. CarPlay is easier to use while driving, Android much more flexible.
Old Jul 12, 2019 | 03:08 PM
  #360
c2fordy5's Avatar
c2fordy5
Cool. I’ll wait on your feedback before I update
