Whistle when starting
Old Jul 10, 2018 | 08:48 PM
ching's Avatar
ching
Default Whistle when starting
I hear a whistle like tweety bird when I start or stop my car. Dealer has no clue.
Old Jul 11, 2018 | 02:15 AM
SNiiP3R's Avatar
SNiiP3R
I’d check the belt tensioner and pulleys. I had to replace that twice already, at 35K and 50K
Old Jul 11, 2018 | 07:27 AM
AJLex19's Avatar
AJLex19
Check that Serpentine belt! I too had to change mine at 54k miles (https://www.mylparts.com/oem-parts/l...elt-99367k1550).
Old Jul 11, 2018 | 10:56 PM
CaptRog21's Avatar
CaptRog21
Just started hearing this yesterday morning when I first start mine up in the morning. Do you hear it every time you start it? Mine seems to only happen first thing in the morning.
Old Jul 12, 2018 | 01:14 AM
ExLextech's Avatar
ExLextech
Have your dealer check the alternator and/or alternator clutch for the whistle sound. Visually watch the nose of the alternator to see if the sound corresponds with the movement of the clutch.
Hope that helps with your noise concern.
Old Jul 12, 2018 | 09:30 AM
bclexus's Avatar
bclexus
The whistle noise you hear for ~90 seconds at cold startup is likely the secondary air pump. This related noise is typical and not an indication of a problem.
Below are a couple of videos that will help you determine if this is what you are hearing.
bobbys450h
Jul 25, 2018 09:13 AM
17gx460
GX - 1st Gen (2003-2009)
Jan 11, 2018 09:08 PM
bigboy0723
Mar 17, 2016 09:25 PM
KonaRX
Jul 21, 2012 01:46 PM
SC300_704
Mar 21, 2007 07:39 AM
