Cheaper replacement for front Brakes and rotors
I was quoted $850 to change my front brakes and rotor with OEM parts at a local mechanic shop. This is just too much. Any other cheap alternatives available?
2013 GS350 RWD FSport
Thanks,
Tony
I have and recommend Akebono brakes and ATE PremiumOne rotors if you go non-OEM and your shop can get them for you (although not sure if they make compatible products for F-Sport RWD models if thats what you have).
The price difference from OEM vs. aftermarket may not be that substantial depending on where you are sourcing your parts. You should check online with MyLParts.com and HouseOfLexus.com to see how much they charge for OEM parts. Then maybe the local shop can give you a quote on just the labor if you bring your own parts.
Dan's video is pretty helpful, although IMHO it makes it look too easy. I think with GOOD appropriate tools and a good impact wrench you can probably get it done in an hour, but I took about 2 hrs or so and then another half hour for a road test, which turned out great. You also gotta spend time cleaning the junk out of the caliper, etc Next time I can probably bang it out in an hour now that I know how to do it. Of course admittedly some of the time today was hunting tools in my house as well as drinking water/taking short breaks because it was hot out today and I was working up quite a sweat...
I still had a few mm on the pads left but they looked pretty glazed over, just wanted to get it done. I probably could have reused my existing rotors but at 92 bucks apiece was easier to just replace.
You must have a Torque wrench to properly set the caliper bolts back on. (57 ft lbs iirc( And taking them off is a total pain in the ***, you will need a hammer or breaker bar, I got lucky and I had a breaker bar which was just small enough to fit in the wheel well and still allow me to use it to break the bolts free.
Useful tip- PAY ATTENTION to the pads when you pull them out, if you keep them intact you can see how the shims go together, and the fact that the rubberized one goes on the back of the actual brake pad.
Also, if you can't get the rotor to come off, and you don't have the bolts to fit in the "assistance hole" an old school wheel puller will work, but don''t just crank on the wheel puller, tension it up several turns and then give the rotor a few whacks with the hammer and it'll pop right off.
-Mike
Also given what I went through today, working on mine when I was all done you know what the first thing I said to myself was? "This isn't that hard, HOWEVER, I can easily understand why a dealer gets like $600+ for this. " It all became pretty clear to me in that moment.
-Mike
-Mike
https://www.ebay.com/itm/LEXUS-OEM-FACTORY-F-SPORT-FRONT-BRAKE-PADS-AND-ROTOR-SET-2013-2015-GS350-2WD/252855946447?fits=Year%3A2013%7CModel%3AGS350&hash=item3adf638ccf:g:Y74AAOSw5VFWHrKm
I also found some EBC brakes/rotors for $321 but not sure how they are compare to OEM? I am not racing so I rather have pads that last long but of course I wouldn't want to sacrifice braking.
https://www.ebay.com/itm/LEXUS-OEM-F...4AAOSw5VFWHrKm
