New car, first mod
Old Oct 12, 2017 | 10:13 AM
yardie876's Avatar
yardie876
Originally Posted by 08swade
To take that trim off you need to remove the plastic under panel (just clips) and I just moved it since there is an airbag plug attached. There are 2 10mm screws on the bottom of the glove box remove them, then empty the glove box and there are 3 ( I think maybe 4 sorry IÂ’m doing this from memory) screws in the top of the glove box remove them and the glove box should drop down the hardest part is there is two screws in the back of the panel, I was able to get to them by feel the one closest to the center was easy there is one closer to the door that I had to loosen a bracket for one of the computers to get better access ( the screws are 8mm and on the back side you cannot see them) then it is just clips it does help to remove the shroud around the radio(just clips) and you will need to move the right side of the center vent out to remove the trim as it links into it. I also removed the side cap of the dash (piece that is clipped in where the door meets the dash but canÂ’t remember if it was required. Use plastic soft pry tools and common sense and itÂ’s not too bad, it took me 30 minutes or so once I figured it out I will be re doing this piece since I stretched a small piece too much and it affected the grain and itÂ’s bugging me. IÂ’ll take pics if you want.
If you could that would be phenomenal. I have a horrible rattle (compliments of my catback lol) and it’s driving me crazy.
Old Oct 12, 2017 | 11:03 AM
08swade's Avatar
08swade
Originally Posted by e60bmw
Looks awesome. I wrapped mine recently in the 3d carbon fiber wrap, I did it with the trim on but I didn't do everything because I couldn't wrap it all. How did you cut out the chrome portion on the cupfolder area? Any tips for removing the center stuff?
The cup holder cover was easy, and it requires the center piece to come out. I will reply later with pics on how. The crome piece on the cover is taped in and can be removed from the back once you get it out, it went back in easy but your 3D Vinyl may make it a tight squeeze(mine was)
05ls430518
Aug 20, 2018 02:56 PM
08swade
Feb 4, 2018 05:56 AM
Joeb427
Oct 3, 2010 10:10 AM
