JoeZ Full Exhaust and California Smog
Old 03-25-17, 07:38 PM
jdpdata
jdpdata's Avatar
Originally Posted by richard203
how much discount will he take off?
Dont know, didn't ask because I'm not waiting for more people to sign up. I'm ready to purchase now.
Old 06-09-17, 08:32 AM
TrevorTran
TrevorTran's Avatar
Did you end up purchasing the Joe Z full exhaust after all?
Old 06-09-17, 08:44 AM
jdpdata
jdpdata's Avatar
Yes I have the Full JoeZ Cat back. Love the sounds it makes at WOT but for most normal driving the drone is very noticeable and extremely annoying. Rattles my car like a cheap Civic too. Not sure if I will keep it.
Old 06-09-17, 09:20 AM
TrevorTran
TrevorTran's Avatar
Wow, sorry to hear that. Not sure if others with the exhaust can chime in with the same conclusion, but doesn't sound like it's a good set up for commuters. Looks like you've had it for maybe 3 months? It's not something that grows on you the more you drive it?
I'd hate to purchase the exhaust and end up with the same conclusion as you, but definitely keep us updated with your future plans!
Old 06-09-17, 09:33 AM
jdpdata
jdpdata's Avatar
I knew about the potential droning from another member mikec78 so I guess it's not a big surprise. Mike stated the same thing and he tried everything possible to get the droning down without any success. I think he eventually swap back the stock Muffler and said that helps a bit..
I don't drive my car daily just on weekend but it still bothers the heck out of me. It doesn't get any better with mileage..only gets louder.
If you daily commute with this setup and expect a quiet car, you'll be very disappointed. Again this is all my personal opinion. Some people may like this setup. Not for me, I want a quiet car. May end up selling my JoeZ and take a loss. Despite my disappointing experience, it is still an excellent Exhaust system. Craftsmanship in second to none.
TrevorTran (06-19-17)
Old 06-09-17, 10:01 AM
rijc99
rijc99's Avatar
I've stopped using full exhaust systems on cars with automatics due to droning sounds. I did have success with axle back systems. Have you tried any axle back only setups?
Old 06-09-17, 07:55 PM
2Squared
2Squared's Avatar
I have an Invidia catback exhaust and at normal cruising speeds where the engine is below 2,000 rpm it's no louder than stock. Thank goodness in Texas having in O2 sensors in the line and ready good is all that's required.
TrevorTran (06-23-17)
Old 06-23-17, 09:26 AM
TrevorTran
TrevorTran's Avatar
Is the drone so loud that you can't have a normal conversation in the car?
Old 06-23-17, 12:05 PM
jdpdata
jdpdata's Avatar
Yes I have trouble hearing my kids in back seat sometimes. When at WOT, it's very loud. Definitely can't hear rear passengers at WOT.
Old 06-23-17, 06:23 PM
richard203
richard203's Avatar
did you try just using the mid pipe? mybe the droning will be lower. or just use the axle back. just switch around to see which one fit you better.
Old 06-23-17, 06:28 PM
jdpdata
jdpdata's Avatar
Yeah planning to do that. Just been so busy with work.
Old 02-07-19, 04:43 PM
todd4566
todd4566's Avatar
I recently did my smog test here in CA... and the technician so so particular I had to remove my Joe Z intake tube.
Old 02-07-19, 04:59 PM
jdpdata
jdpdata's Avatar
I'm using stock intake, I should be fine getting smog done.
Only thing I'm concern about is California Assembly Bill (A.B.) 1824.
My exhaust is pretty loud, but I haven't measured if it's more than 95db.
Old 02-07-19, 08:15 PM
viperr
viperr's Avatar
Db meter should placed at height level and 19.5 inches away from the exhaust tip with the microphone set at a 45 degree angle. Decibels should be measured once the car has warmed up and then rev to 2500 rpms. If you exceed 95db at that point, then it will be illegal.
Old 02-08-19, 08:44 PM
richard203
richard203's Avatar
the smog tech tell you to remove the intake because its illegal. ur joz intake is not carb legal, if it is he wont have ask you to remove it.
Guedzou
IS F (2008-2014)
19
08-09-17 02:24 PM
saucn
11-30-15 11:17 PM
RyPeredo
05-21-13 06:56 AM
vha23
Performance
04-14-11 04:25 AM
max90034
IS F (2008-2014)
06-02-09 09:33 PM
Quick Reply: JoeZ Full Exhaust and California Smog
