LED Reverse Lights DIY
Old Nov 5, 2016 | 03:00 PM
  #31
tejanp's Avatar
tejanp
Originally Posted by DallasDave
Just put the LED bulbs in for my reverse lights. Looking forward to seeing them at night. It's pretty easy to tell the difference, even in the daylight.
360-degee Extreme Bright 50W CREE High Power 906 912 921 W16W T10 LED Back Up Reverse Light Bulbs, Parking Lights
Very nice! The bulbs you linked at the bottom, are they CREE LEDs? the Amazon page it goes to does not mention CREE.
Old Nov 5, 2016 | 03:30 PM
  #32
DallasDave's Avatar
DallasDave
I got them from ijdmtoy.com
http://store.ijdmtoy.com/50W-CREE-Hi...s-p/10-088.htm
It should be the same bulbs as someone else posted here earlier. The seem to be made out of aluminum and feel like a good quality.
Old Nov 5, 2016 | 07:21 PM
  #33
xRYD3Rx's Avatar
xRYD3Rx
This is exactly what i have super bright ! Its the way to go if anyones changing their reverse light.
Dont worry about the 50W because its being used as a reverse light purpose and its on for few seconds.
However i wont recommend this for parking light or a different application if the light will remain on for long period of the time its to strong.
Old Jan 4, 2017 | 09:05 PM
  #34
er34's Avatar
er34
Finally got 'er done.
I was finding the backup camera a little dim sometimes backing into dark parking spaces. This should help with that.
The phone camera doesn't make it obvious, but look at the wall for the difference in light output.
Old Mar 18, 2017 | 08:15 PM
  #35
comtrans's Avatar
comtrans
Installed these:
JDM ASTAR Extremely Bright 360-Degree Shine 921 912 90-EX Chipsets LED Bulbs For Backup Reverse Lights, Xenon White https://www.amazon.com/dp/B01GGK6QDW/ref=cm_sw_r_cp_apip_rcUEc1GLz7vdY
($17.99 shipped 2-day with Amazon Prime)
HUGE improvement over stock lamps. Easy to install and as previous posters have noted, no need to remove all 15 retainer clips. The few around where the lamps are housed is enough (note: when removing clips, be sure to pull straight down or you risk breaking them as they're simple plastic).
Old Mar 18, 2017 | 10:38 PM
  #36
fungke's Avatar
fungke
Thanks for sharing.
That is a significant difference.
Old Mar 19, 2017 | 08:15 AM
  #37
Chavez562's Avatar
Chavez562
Looks great!
Rosson3ri
May 2, 2016 08:58 PM
yycdave
Apr 3, 2014 07:23 PM
SonyHome
Jan 12, 2014 08:03 PM
polo2883
Aug 2, 2012 12:52 AM
Phanatik
Jan 13, 2009 10:44 PM
