Sorry if this has been ask before. I want to stick with 19" wheels but with wider 9". Will 19x9 45 offset with 265/35/19 all around be fine? Btw, the car is lowered on tanabe springs. Thanks in advance!
From my memory no it really won't be. I have a RWD 2013 and wanted to do exactly what you're thinking; switch to 265 at all four corners but in measuring everything out you'd end up with roughly 1-2mm of clearance on both sides of the front tire which wasn't enough for my piece of mind; tires wobble under hard cornering. I'm also at stock height. You'll note that even the GSF only goes up to 255's in the front.
I was planning on taking a rear rim and using a spacer to push it out to make everything line up, and while I don't remember the eventual offset of the rim + the spacer, I can relay the disappointment
Measure everything out against your current setup to verify; let me know if you do it and it works out! I'll follow in your footsteps!
I'll have to do more researching before I go ahead with the square 265/35 tire setup. I think 255's might be a better idea. Worst comes to worst, I'll just go with staggered tires. Thank you for your input.
