led light replacement guide?
It takes patience and care, but each side should only take you about 20min or so: https://www.clublexus.com/forums/gs-...ht-led-13.html
Here's the link: http://www.vleds.com/shop-bulb-numbe...-led/6-5k.html
I have a '13 GS - the '13 model year GS didn't have the power folding mirrors. If it bothers you enough i'd definitely take it to the dealer and show them the lack of synchronization as they fold in/out but I wouldn't mention that you changed the bulbs yourself.
hi guys..
I'm in the midst of replacing all the halogen bulbs on the car..
so far i have done the door light with led bulbs but I need some help with the others..
Turn Signal Light Bulb Rear is 7440.
Turn Signal Light Bulb Front is 7444NA
Vanity Mirror Light Bulb Is 175
Reverse light is 921
which led upgrades did everyone used? for the turn signal light front.. I would need amber ones correct? do i need amber ones in the back also??
and the biggest question.. what's the size for the puddle lamp? i looked at sylvania but can't find the puddle lamp one? i want something that's bright.. the halogen ones in there are just way too dim.
thanks
thanks
Hello. Would this light bulb list be compatible with 2016 GS F Sport by chance?
mikegs2006
Aug 23, 2011 08:45 PM
