Brake Change
Old Aug 8, 2015 | 08:44 AM
jhontelj's Avatar
jhontelj
Default Brake Change
I have a 2013 GS non-f. I was wondering was changing the brakes as simple as it is on a 2006. A link to a post would be great.
Old Aug 8, 2015 | 08:57 AM
08sgmis350's Avatar
08sgmis350
I'm not too sure about non fsport but I'm pretty sure it's same procedure as fsport. Very simple. Take out pin hold clip from anti rattle then slide the anti rattle pin out. Wiggle and compress the brake pads and you can pull the pads out. Make sure remove the brake fluid cap and look at the fluid level when u compress the Pistons. That's it! Very easy and fast for front brake. For rear, just unbolt brake caliper slider bolts from top and bottom then u can lift up the rear caliper. Then u can access rear brake pads. This link is from 2gen is forum but brake looks like that on 4gs.
https://www.clublexus.com/forums/sus...g-caliper.html
Old Aug 8, 2015 | 09:02 AM
jhontelj's Avatar
jhontelj
Originally Posted by 08sgmis350
I'm not too sure about non fsport but I'm pretty sure it's same procedure as fsport. Very simple. Take out pin hold clip from anti rattle then slide the anti rattle pin out. Wiggle and compress the brake pads and you can pull the pads out. Make sure remove the brake fluid cap and look at the fluid level when u compress the Pistons. That's it very easy and fast for front brake. For rear, just unbolt brake caliper slider from top and bottom then u can acess the rear brakes. This link is from 2gen is forum but brake looks like that on 4gs.
Thanks......
Old Aug 8, 2015 | 10:30 AM
jhontelj's Avatar
jhontelj
A picture of my old vs new pads
Old Aug 8, 2015 | 11:13 AM
rijc99's Avatar
rijc99
Make sure your e-brake is not set to auto.
And make sure you remember the shims.
HiPSI
Jun 7, 2019 11:58 AM
khizr23
Apr 26, 2016 01:28 PM
IS350atWOT
Suspension and Brakes
Feb 18, 2010 11:33 AM
Sunspyre
Feb 17, 2010 11:26 AM
DaKi3241
May 23, 2009 10:42 AM
