DIY Trunk LED Light Strip Guide
Old Oct 29, 2015 | 01:19 PM
  #76
AJLex19's Avatar
AJLex19
I went the strip light route and bought the iJDMTOY brand strip light for 10 bucks. It illuminates the entire trunk quite well.
I ended up drilling a hole through the plastic lens covering the 194 bulb in the trunk and running the wire through that drilled hole. Pasted the LED strip on the outer side of the plastic lens using 3M mounting tape.
I understand why folks go the route of the LED board - its a bit of a cleaner install but I am happy with the output of the LED strip.
Old Nov 20, 2015 | 10:15 AM
  #77
allivant's Avatar
allivant
may be a dumb question but what is this for?
Old Nov 20, 2015 | 12:05 PM
  #78
bclexus's Avatar
bclexus
That is an adapter to obtain voltage from a festoon type lamp socket. The adapter replaces the original festoon lamp...and the female white plug provides voltage for the new lamp through a pigtail that plugs into the white plug.
Old Nov 20, 2015 | 12:06 PM
  #79
puffdaddy's Avatar
puffdaddy
It's a festoon base adapter for use in many interior dome lights. Not needed for trunk applications
Old Nov 20, 2015 | 01:20 PM
  #80
allivant's Avatar
allivant
lol at first glance i thought it was a fuse. i thought what the hell is the spring for?
Old Dec 25, 2016 | 08:35 AM
  #81
markpjoyce's Avatar
markpjoyce
How do you remove the light cover in a 2016 GS350? I tried a couple times but if I pry any harder I am concerned I will break it.
Old Jan 11, 2017 | 02:24 PM
  #82
conclevage's Avatar
conclevage
Thank you...will do this mod for my trunk, as well.
Old Jan 11, 2017 | 03:04 PM
  #83
Wincer94's Avatar
Wincer94
Cool, want to do this as well to my new car. Please post a link where you got your part. Thanks.
Old Jan 11, 2017 | 04:28 PM
  #84
phins2rt's Avatar
phins2rt
Here is the one I bought. Don't get the 24 led board. You will blow a fuse!!
http://www.ebay.com/itm/111198436944?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
cb80923
NX - 1st Gen (2015-2021)
54
Feb 16, 2023 09:58 PM
bmwlexus09
Jan 4, 2017 04:47 PM
mcfancy
RX - 4th Gen (2016-2022)
Sep 20, 2016 12:38 PM
XxGoKoUxX
Feb 3, 2015 10:33 PM
ReyRey305
May 25, 2010 10:03 PM
