Sensors Going Wacko!
Old Mar 19, 2013 | 04:38 AM
bigblack06's Avatar
bigblack06
Default Sensors Going Wacko!
So basically when I got my vinyl done he did the front bumper and sensors, per my request. The sensors were fine but maybe 3 days later they started to go off with nothing in front of them. My question is anyone that has had there sensors done can you take a close up pic of your F-Sport bumper, and post to this thread or PM me. Thanks for your help it's really appreciated.
UPDATE: The sensors are working now with no problems I have not had any issue's with the sensors going off randomly.
Old Mar 19, 2013 | 07:39 AM
sydtoosic's Avatar
sydtoosic
was there any ice or snow on the sensors? that will cause them to activate... it happened to me until i got out and saw that there was a fine sheet of ice on my sensors, i cleaned off the ice... problem solved.
Old Mar 19, 2013 | 07:48 AM
Outrage's Avatar
Outrage
My front proximity alert does the same thing when ice or snow layers on the front of the vehicle. Yesterday, I received an alert asking that I remove ice from the front parking sensors every time I came to a stop. That was the first time I received that message. In previous cases, the sensors registered that I was at the minimum distance and would give me a fast tone when I slowed down to a certain speed.
As far as vinyl, consider this: There are different thicknesses of vinyl. Perhaps the sensors are only affected when using vinyl above a certain thickness.
Old Mar 19, 2013 | 08:22 AM
bigblack06's Avatar
bigblack06
Nope no snow, car is still parked in the garage, clean as a baby's butt! I think it's the vinyl but why would it take so long to react. I know some people have gotten there's done as well. What was the outcome I need my guy to fix this but want to make sure it doesn't happen again.
Old Mar 19, 2013 | 08:27 AM
Outrage's Avatar
Outrage
Has the temperature recently changed? If the vinyl thickness were the cause, it would be reactive to very small changes, potentially those caused by the vinyl's expansion and contraction. Also, I believe vinyl will continue to adhere to an object over a given length of time (days or weeks?). Those are my theories.
Old Mar 19, 2013 | 08:47 AM
terrycs's Avatar
terrycs
I wonder if there is a way to calibrate those things?
Old Mar 19, 2013 | 08:53 AM
Outrage's Avatar
Outrage
I think it might be accessible through the "hidden menu":
https://www.clublexus.com/forums/gs-...gured-out.html
Old Mar 19, 2013 | 09:19 AM
bigblack06's Avatar
bigblack06
Could be the contraction, temperature has been the same for the most part nothing really warm. My thought is that the sensors have to be free from the bumper, so he needs to cut them loose instead of having the whole bumper wrapped with the sensors. If that makes sense. The sensors are the rubber rings correct.
Old Mar 19, 2013 | 09:29 AM
hypnotika's Avatar
hypnotika
What type of film did he put on? I have 3M that cover my sensors too but it's so thin I haven't had any problems so far. No snow here and she's always garaged.
Old Mar 19, 2013 | 09:44 AM
djpeakSD's Avatar
djpeakSD
Thats weird cause I plasti dipped mine and they are fine. Maybe the vinyl is different though. If it persists you can always buy the black sensors, but obviously that is more money and not ideal.
Old Mar 19, 2013 | 11:42 AM
bigblack06's Avatar
bigblack06
Yes he used 3M, do you mind taking a close-up pic of your sensors. She is garaged as well, she is actually garaged and covered with a car cover from the dust elements.
If it needs to come to that I will but don't want to spend that money yet if it's necessary.
Old Mar 19, 2013 | 02:04 PM
hypnotika's Avatar
hypnotika
Here are a couple I had on my phone. I'll get some more close ups tonight when I get home (west coast).
Old Mar 19, 2013 | 02:37 PM
bigblack06's Avatar
bigblack06
Mine looks exactly the same, yeah please closer pics. I would take a pic buts its cold and slushy out here!
Old Mar 19, 2013 | 04:14 PM
052SI's Avatar
052SI
Maybe the edge is very slighlty coming up or there's the smallest bit of lost clearence?
Old Mar 19, 2013 | 05:05 PM
e39ng's Avatar
e39ng
You may want to check this TSB to see if your VIN is included and then have the dealer to check for any error code....
