using paddle shifters?
Cliff notes...
IF your going to use the "Paddle Shifters", slap the gear selector into "M" Mode and have fun..!!!
For extra fun, make sure you have also selected "Sport + "..
There is really no point in using the Paddle Shifters in regular D mode and/or Normal drive select mode.
That is all
... coming from an IS-F daly driver..
~ Joe Z
That is all
..... coming from an IS-F daly driver..
~ Joe Z
I use the paddle shifters in “D” mode all the time because I drive 30 miles in stop-n-go traffic. I can be cruising along at 65 and see the traffic slowing and hit the minus button 2-3 times depending on how quick I want to slow down (2 hits = 4th gear, 3 hits = 3rd gear). This will use the engine to slow the car. Then when you accelerate for a short time, it goes back into “D” mode and works as an automatic. If traffic continues to move slow, I will put it into “M” mode to hold it into a lower gear. If I’m in 3M and come to a complete stop, the car shifts to M1 automatically. Then I have to put it back into “D” or manually shift with the paddle or shifter. It’s nice to have the different options to shift since every drive is different. 1200 miles and loving the F Sport a lot more than my 2010 GS350 I traded!
but i have to say, to stop a car, brake is what you should use, not the engine. it's much cheaper to change pads and rotors
Thanks for the info lexsteve
From the user manual
Automatic deactivation of shift range selection in the D position
Shift range selection in the D position will be deactivated in the following situations:
* When the vehicle comes to a stop
* If the “+” paddle shift switch is operated when the shift range is in 5
* If the accelerator pedal is depressed for more than a certain period of time
* When the shift lever is shifted to other than D
I race on the track and everyone uses engine braking or as we say rev matching or heel toe thats the most effective way to slow down and enter the corner that will not ruin your engine and pad and rotors will last longer
but for normal daily driving on an automatic, that's simply wear on your engine and tranny. i am not talking about problems coming up tomorrow, but it's more wear over time for sure, it's simple physics. if you let the car slow down enough where downshifting doesn't cause stress on the engine and tranny, then that also means the downshift helps nothing.
saulrosenb
Nov 4, 2018 05:35 AM
outlaws
Jul 3, 2009 07:33 AM
