Alternator
Old Sep 12, 2025 | 03:26 PM
Boymom3's Avatar
Boymom3
8th Gear
Default Alternator
I am replacing my alternator on my 2013 Lexus Gs 350
having a very hard time getting oem alternator out.
I can’t find any YouTube videos for 2013,
Any tips would be very appreciated
Old Sep 12, 2025 | 04:41 PM
Mangsailor's Avatar
Mangsailor
Veteran: Navy
If you search for posts I've made, I have a few tips on getting that thing out. It is NOT easy getting to the mounting bolts and clips, but it's doable.
There's a couple clips and a fan controller module on the radiator fan support you need to also take out (and you need to use a JIS Philips bit or you'll strip the heads!)
Old Sep 12, 2025 | 08:35 PM
PK_Celsior's Avatar
PK_Celsior
I am not sure if you are aware but there is a bolt behind the alternator. I did a drain and refill on coolant as I removed the upper radiator hose.
https://www.clublexus.com/forums/gs-...placement.html
Old Sep 13, 2025 | 04:20 AM
Boymom3's Avatar
Boymom3
8th Gear
Thank you I will have to do a search thru your posts my fiancé thinks taking front driver tire off may help get to the bracket
Old Sep 13, 2025 | 07:18 AM
Boymom3's Avatar
Boymom3
8th Gear
yes we are currently trying to get that bolt out it is a nightmare
Old Sep 14, 2025 | 04:02 AM
Mangsailor's Avatar
Mangsailor
Veteran: Navy
Here's my thread on taking it out (as well as partial rebuild of it): https://www.clublexus.com/forums/gs-...placement.html
If I remember right, I used a 1/4" drive ratchet and some u-joints/extensions to get to that bolt nut. The bolt in the front is easy, the nut is a pain. I think I stuffed some papertowel in the socket when I went to put it back in, as well as some mirrors so I could see the stud. You may have some luck breaking off a bit of fridge magnet and putting that in the socket to keep the nut from falling.
Old Sep 14, 2025 | 05:26 AM
Boymom3's Avatar
Boymom3
8th Gear
Thank you we got the job done it was brutal the mirror helped tremendously being in Florida it’s hot & it was exhausting
Have a great day
Fit1too
RX - 1st Gen (1999-2003)
Apr 22, 2022 10:30 AM
Dirteeboy
Apr 1, 2022 04:12 PM
Hbhandal
Nov 30, 2015 01:52 PM
grumpi300
Apr 15, 2013 08:52 PM
silkiechic
Pacific
Feb 5, 2006 10:27 AM
