Electronic parking brake malfunction
It may be the electronic parking brake (EPB) module or the sensor...
Any mishaps recently or issues with the battery?
https://www.clublexus.com/forums/gs-...l#post10567799
I put in a new battery 2 months ago. I also spilled a 5 gallon jug of water in the trunk about a week ago. I wonder if that could have shorted anything?
Here's what to do:
RESET PARKING BRAKE MEMORY without TECHSTREAM
(a) Turn the engine switch off.
(b) Using a shorting wire like a paper clip, connect terminals 13 (TC) and 4 (CG) of the DLC3.
(c) Turn the engine switch on (IG).
The parking brake indicator light (red) will blink rapidly at 0.25 second intervals.
(d) Perform both of the following procedures within 8 seconds:
(1) Perform the following with the electric parking brake switch twice: lock condition → off → release condition → off.
(2) Perform the following with the brake pedal: depress → release → depress → release.
(e) With the engine switch on (IG), disconnect the connection of terminals 13 (TC) and 4 (CG) of the DLC3.
(f) Check that the parking brake indicator light (red) blinks at 1 second intervals.
If terminal 13 (TC) and 4 (CG) of the DLC3 are not disconnected, the blinking pattern (1 second intervals) cannot be checked. If the parking brake indicator light (red) blinking pattern (1 second intervals) is confirmed, the clear procedure is completed. If not confirmed, repeat the procedures above.
ACQUIRE TENSION SENSOR ZERO POINT
After performing reset memory, perform the release control. Check that the parking brake indicator light turns off.
Yet another reason to have the battery replaced at the dealership with a Lexus branded replacement battery (with a 7 year warranty) - because the Lexus tech will be responsible to make sure that changing the battery doesn't cause a problem with any number of things we've heard people having problems with (e.g. HVAC, NAV, Head unit, Sunroof, Power Seat, Power Telescoping Steering Wheel, Door Locks, etc.) - - and if changing the battery does cause a problem with anything the tech will fix it... If you change the battery DIY or have some auto shop change it, you are on your own getting getting things fixed...
This said, if the EPB locks On and cannot be released while at Costco or Walmart or some auto parts store when replacing the battery you're not driving home - because the owner or the shop employee has no clue why the parking brake won't release or how to fix it! People have had to get their car towed in to the dealership when this has happened. However, if this happens at a Lexus service department the Lexus technician knows how to correct the issue so you can be on your way...
Don't think it's because of the battery install 2 months ago because everything worked fine including the presets of seats and radio. I'm more inclined to think the water spill has something to do with it because this happened shortly after that. It has seeped all the way through to where the spare tire sits and I had to pour out the water from there and dry the area as best I could
Nah. Not doing anything that cost ineffective ever again.
Also, I have strong evidence Lexus technicians don't even read their own factory service manuals, despite having full access to TIS. Very strong evidence.
LiFePO4 batteries are not recommended for use in extremely cold conditions, which can be half the U.S. and all of Canada.
But even of greater concern is the fact that LiFePO4 batteries should not be charged below freezing as it can cause irreversible damage to the battery cells.
Wow, did you know that? That's not good!
In cold climates LiFePO4 batteries may need heat blankets to maintain optimal performance! LiFePO4 batteries are not recommended for use in cold conditions and in extremely cold conditions you're just begging for problems.
I really cannot imagine anyone wanting any part of dealing with LiFePO4 batteries!
But I sure wish you the best of luck with the LiFePO4 batteries in all your cars!
https://ecotreelithium.co.uk/news/li...erature-range/
Here are the facts of the matter:
"Extreme caution must be taken when charging LiFePO4 batteries while the batteries are below 32°F/0°C to avoid damaging the batteries. Some manufactures claim that their LiFePO4 batteries are easy to charge in freezing weather - just charge them at very low rate. But most all battery experts recommend against it."
