Dongar adapter taps a source that’s hot when car is off?
Old Jan 7, 2025 | 06:15 PM
GoodRevs's Avatar
GoodRevs
Default Dongar adapter taps a source that’s hot when car is off?
Does the Dongar adapter for our 4th gen GS tap a power source in the rearview mirror that’s hot even when the car is off? The rearview mirror dimming function I imagine is a cold power source when the car’s off, but the garage door buttons on the rearview mirror are hot when off. I’m thinking of installing one of the Blackvue LTE cameras with 10min of free live stream remote viewing.
Old Jan 7, 2025 | 06:58 PM
bclexus's Avatar
bclexus
Just be aware that the camera's constant 30 mA (0.03 amps) load in idle mode, while not terribly high, is going to be a constant drain on your battery.
Old Jan 8, 2025 | 02:38 PM
EAST's Avatar
EAST
Does the adapter connect with T-Taps, or grab power some other way. Either way, Yea, there is a constant hot, and switched on, along with ground within the wiring for the mirror.
At least for the post facelift, the red wire is constant, yellow is switched, and white (likely with black stripe) is ground. Since there isn't much room to tap, you can follow those wires down a little and tap the corresponding wires (the lower white circle). That is what I use for my Viofo hardwire kit which has a low voltage cutoff so it doesn't run down the battery.
es250fsport
ES - 7th Gen (2019-2025)
Apr 22, 2024 01:57 AM
Arcadian
Dec 8, 2021 06:10 PM
pierre60
IS C
Apr 17, 2019 02:09 PM
Badasilva1
Aug 16, 2016 12:42 PM
icegoffy
Oct 30, 2015 10:57 PM
