Interior Door Panel Material Wrinkling
Old Oct 7, 2024 | 06:36 PM
New2Lex17's Avatar
New2Lex17
10th Gear
Default Interior Door Panel Material Wrinkling
Hello Lexus family!
Has anyone had an issue with the material on their door panel getting wrinkled? Aside from getting a new panel have you found a way to smooth it out? I talked to a vehicle upholstery professional and was told they cannot replace the material because it is glued to the door panel. Any suggestions would be greatly appreciated 🙂.
Old Oct 8, 2024 | 05:44 AM
charley95's Avatar
charley95
I have that same issue on my RX but it's not as bad as yours.
Old Oct 8, 2024 | 06:23 AM
4gs_dylan's Avatar
4gs_dylan
This seems to be a common problem across a lot of Toyota/Lexus models. I'm sure you'll be able to find an upholstery shop to reupholster the door panel, but it'll either be too costly or won't be a good match. I'd try looking for a good used one online.
Old Oct 8, 2024 | 03:48 PM
AJLex19's Avatar
AJLex19
No real fix for it as others have mentioned. It has come up quite a bit over the years on the 4GS sub-forum. The common fix is to get the door panel replaced. A few previous/helpful threads and posts:
https://www.clublexus.com/forums/gs-...oming-off.html
https://www.clublexus.com/forums/gs-...-wrinkles.html
robfrmsd
ES - 7th Gen (2019-2025)
15
Jan 18, 2024 06:38 PM
MX5NES350
GX - 2nd Gen (2010-2023)
Nov 1, 2017 08:06 AM
stanley186
May 3, 2015 11:42 AM
roumieh200
Sep 26, 2007 04:52 PM
