Trunk doesn't close with button
Old Dec 11, 2023 | 07:56 AM
tubthumpin's Avatar
tubthumpin
Default Trunk doesn't close with button
When I open the trunk and hit the button for it to close, it will start shutting, and when it gets down to the latch, it just opens back up
has anyone experienced anything like this?
2018 GS
Old Dec 11, 2023 | 08:59 AM
bclexus's Avatar
bclexus
I guessed you've checked to see if anything in or around the latch is blocking it from closing and reversing? Also, check the arms of the trunk lid for any kind of blockage or something that could cause a resistance to fully close.
Old Dec 11, 2023 | 09:01 AM
charley95's Avatar
charley95
Fuse maybe?!
Old Dec 11, 2023 | 09:03 AM
bclexus's Avatar
bclexus
Originally Posted by charley95
Fuse maybe?!
It wouldn't be a fuse if the motor works to partially close it and then to reverse it.
Old Dec 11, 2023 | 09:39 AM
Mangsailor's Avatar
Mangsailor
Veteran: Navy
Check and make sure none of the weatherstripping has come off of the pinch joint or trim in the trunk area. Maybe you moved a bit of it inadvertently when you removed something from the trunk or put it inside.
Old Dec 11, 2023 | 10:30 AM
charley95's Avatar
charley95
I did miss that.
yardie876
Jul 6, 2023 04:25 PM
eelliiss
Dec 17, 2021 06:02 PM
jdanielca
Dec 19, 2019 12:43 PM
dynamax
Sep 13, 2009 09:57 PM
dat-is350
Dec 28, 2006 02:36 PM
