Need help - communication failure
Old Oct 9, 2022 | 04:08 AM
leonzack's Avatar
leonzack
New Member
Default Need help - communication failure
Hello, I have a 2008 Lexus GS300 after restyling.
I get an annoying error:- it comes and disappears on its own and it returns on its own.
I would appreciate your help if someone knew and was able to fix it.
Another thing - the moment the fault appears - the air conditioner stops cooling. As soon as the fault disappears - the air conditioner returns to cooling
code fails :
u0073
u0100
u0123
u0124
u0126
Old Mar 6, 2024 | 08:38 PM
Yohane333's Avatar
Yohane333
2nd gear
Did you ever fix it? I have the same issue on my 2007 IS350. Thinking it’s the yaw rate sensor.
Old Mar 7, 2024 | 07:43 PM
ibidu1's Avatar
ibidu1
More likely you have a voltage issue. Either alternator, bad battery, loose battery connection etc. If you have had the alternator replaced with a china alternator or any other then denso or oem alternators then I would suspect that.
When voltage drops, or gets a dip. High voltage parts go offline, like the electrical steering, abs braking etc. I would monitor voltage, while driving.
Jiang
Aug 10, 2022 12:25 PM
predacon47
IS F (2008-2014)
Nov 9, 2021 10:02 PM
/209JOHN\
VIP Style
19
Apr 24, 2012 07:26 AM
johnee78
Maintenance
Dec 29, 2008 05:05 AM
nikunj78
Jul 8, 2005 01:25 PM
