Replacing fog light assembly
Old Jul 3, 2022 | 12:10 AM
energie8's Avatar
energie8
Default Replacing fog light assembly
Has anyone replaced their fog light assembly? Do I need to remove the bumper to take it out or go behind the fenders etc. TIA
Old Jul 3, 2022 | 01:34 AM
ibidu1's Avatar
ibidu1
Maybe you can get away with just removing the splash gaurds and reaching inside, as the fog lights are mounted under the reinforcement so i doubt you have to remove the bumper.
Whats your reason for replacing them did you crack them or because there fogged up?
Old Jul 3, 2022 | 05:17 PM
CowBoE's Avatar
CowBoE
When I removed the front bumper, the fog light remained attached to the front bumper. I just had to disconnect the fog light power cable.
Just looked through my old video:
And at 11:55 mark in this video, looks like fog light is snapped in with tabs at around the edges close to the bumper.
This makes sense, since the bumper is thin, there is no way to bolt this on to the bumper.
If you remove front tires and under engine splash shields, and pry back on the wheel area splash guards,
you might have some access to the fog light assembly, although, it might still be difficult to undo the clips with limited view and hand reach.
If you need more room, you should be able to just remove the bolts and plastic retainers on the side and bottom
of the bumper (vs. completely removing it), and then push out the bottom of the bumper forward a bit to make more room
since the bumper is bit flexible rubbery plastic. (Instructions on what to remove where are all captured in above video).
If all else fail, you at least have the instruction to remove front bumper in the video.
Just note that it'll help to have second person, particularly on the reinstall to get the bumper snap back into correct position.
Also, take good pictures on the bottom of the bumper in terms of what parts (bumper vs. undershield) go under or over each other.
I didn't capture this on video, and took me several attempts to find the right way to put the bottom side back in properly.
Also, bolts and plastic retainers size and thickness can vary, so keep an accurate track of what came out of where.
If you don't, it'll get really confusing later.
Did your fog light assembly crack or you are trying to replace with something better?
If you just want to replace the bulb, you can do that without completely removing the bumper.
Old Jul 4, 2022 | 01:53 PM
energie8's Avatar
energie8
Thanks guys, the first time was tricky but after that it was smooth sailing. I wanted to replace them because I did a retrofit
Old Jul 4, 2022 | 03:13 PM
CowBoE's Avatar
CowBoE
To help future readers, you should detail what you had to do to replace the fog light assembly.
tameratto
Jan 9, 2017 06:39 AM
Sheadninja
Dec 9, 2015 08:27 AM
Rich27
Dec 12, 2013 05:39 PM
qgoat
Lighting
Mar 21, 2007 09:45 PM
Marc-P
Feb 5, 2007 09:08 PM
