JDM Headunit Swap
Old Mar 21, 2022 | 06:55 PM
Baz001's Avatar
Baz001
Default JDM Headunit Swap
I have a 2008 Lexus GS 450h with a japanese headunit, and I am looking to swap the headunit with an English OEM headunit (maybe from the UK or Australian, depending on what I can get cheaper). I plan to also add a Grom Vline2 to the system sometime down the line.
Is there anything I have to worry about regarding the Harness connectors on the back? I can see that the connectors on the back look very different. I am unsure if I will lose the basic functionality such as AC Control, Hybrid information screen, etc. Also, is it true that the Japanese headunits have compatibility issues with the Grom Vline2 compared to the other variants (Not too sure on this)?
My headunit has Navigation, but no Mark Levingson.
The replacement units look something similar to this:
https://www.ebay.co.uk/itm/LEXUS-GS450H-2008-RHD-RADIO-CD-PLAYER-GPS-HEAD-UNIT-86120-30G20-86111-30860/383661648136?pageci=097233a2-e228-4422-96a2-d7ab00a1eae6&redirect=mobile
https://www.ebay.co.uk/itm/LEXUS-GS-2008-RHD-Navigation-System-Head-Unit-86111-30430-86120-30D30-2353132/265281331841?pageci=f026afaa-8635-475d-b3d4-bb47cbc3bfe4&redirect=mobile
Old Apr 2, 2022 | 09:28 PM
iamohk's Avatar
iamohk
https://www.ebay.co.uk/itm/LEXUS-GS4...edirect=mobile
https://www.ebay.co.uk/itm/LEXUS-GS-...edirect=mobile
not advice on a swap, but there is a way to change your language settings and map settings. try to dive into your settings for the language setting and switch that. After that access the secret menu by following this tutorial:
. After that follow this tutorial:
and you should be able to access system language and map settings. Best of luck
Old Apr 3, 2022 | 04:37 PM
Geegeeup's Avatar
Geegeeup
Default geegeeup
I have recently bought a jap import lexus GS 40 which has a fault associated with thr precision collision system light coming on after a few klicks and being unable to extinguish unless with the off key . the toyota people have had it for days "looking into it " and now say they are unable to help because everything is in japanese . I have found a source that sells a reprogrammed harddrive that replaces the original with the only loss being the lines on the reverse screen . I have contacted an car audio expert for assistance to do the replacement but he is reluctant to do this for me because he is not sure of its reliability . has any one used this hard drive and can give me some reassurance please -I am from Hamilton New Zealand . meanwhile I will try the method explained above
Old Apr 4, 2022 | 04:40 PM
gromaudio's Avatar
gromaudio
Vendor
GROM VL2 unit is compatible with this stereo. No need to replace the headunit unless it is DOA.
https://gromaudio.com/store/vline/grom-vl2-lex5ls.html
Acrad
GX - 2nd Gen (2010-2023)
202
Jan 8, 2022 07:47 PM
swaangin
Sep 4, 2021 07:45 PM
arruda89
RC F (2015-present)
Apr 8, 2020 02:55 PM
Beatmd
Mar 19, 2019 07:47 AM
2000 ls400
Dec 2, 2011 01:58 PM
