Rear trunk strut replacement
Old Oct 30, 2021 | 11:10 PM
CowBoE's Avatar
CowBoE
Default Rear trunk strut replacement
When I bought the car couple of years ago, the OEM struts were already not working.
I ordered one from Amazon, and it totally didn't fit and had to return it.
Then I got another (ECCPP), and this also didn't fit naturally.
I had to move the trunk door up and down to get it to fit.
Well, after just 10K miles, one of the struts popped out of the ball joint.
This time, I got the BOXI brand, which was little bit more expensive than the ECCPP,
and it fit perfectly. We'll see if this will last longer than the ECCPP.
If you guys know of a reliable trunk struts for this car,
please let me know. Thanks,
Old Oct 31, 2021 | 12:50 AM
ibidu1's Avatar
ibidu1
Awesome, I need rear struts and front ones aswell. You might want to lube your hinges if you are having a hard time lifting the trunk
Old Nov 1, 2021 | 06:04 AM
CowBoE's Avatar
CowBoE
Originally Posted by ibidu1
Awesome, I need rear struts and front ones as well. You might want to lube your hinges if you are having a hard time lifting the trunk
Surprisingly my 15 year old hood struts are still holding up, perhaps it's because trunk is opened far many more times than the hood.
That's a good idea on lubing the hinges. I'll do it.
Old Nov 2, 2021 | 08:14 PM
CowBoE's Avatar
CowBoE
One of the viewer to my channel replied that following Stabilus is what Lexus came with originally. Amazon says, it doesn't fit GS300/GS350, but I've seen that happen before.
If my current one craps out, this is the one I'll try.
Amazon Amazon
Old Nov 3, 2021 | 05:26 AM
ibidu1's Avatar
ibidu1
https://www.amazon.com/Stabilus-Sach...s%2C172&sr=8-1
Heres an article that may be true to what that poster claimed
https://www.reuters.com/article/auto...8L4DN420121004
Never heard of stabilus as a supplier for toyota, but by comparing the pics they do look similar. You can find stabilus on rockauto there only $14 each side. https://www.rockauto.com/en/moreinfo...t=1404&jsn=392
Old Nov 3, 2021 | 08:07 AM
CowBoE's Avatar
CowBoE
Good info. I'll save the rockauto info.
I just don't trust these aftermarket struts will last a long time.
I'll give Stabilus a try on next failure.
Lesly1
Aug 18, 2016 06:02 PM
Harold57
Apr 27, 2013 01:14 PM
GS300 I6
GS - 1st Gen (1993-1997)
12
Feb 25, 2009 08:58 PM
Rahstyles
Jan 31, 2009 08:29 PM
mrblister
Jun 11, 2008 05:07 PM
