High mileage GS
Old Aug 18, 2021 | 06:47 PM
xjokerz's Avatar
xjokerz
Default High mileage GS
What are some high mileage amounts that you've heard of this generation GS? Anything above 250k and running strong? Concerned about engine longevity with the direct injection.
Old Aug 19, 2021 | 09:45 PM
mrbondy's Avatar
mrbondy
I believe none of the engines on the GS just have direct injection
They have both port and direct injection
Shouldn't be any problems with carbon buildup
Old Aug 20, 2021 | 05:33 AM
TurdGS300's Avatar
TurdGS300
Mine's a 2006 GS300 RWD with 260000km. And burns oil likely due to carbon build-up. Direct Injection only I believe.
Old Aug 20, 2021 | 10:37 AM
xjokerz's Avatar
xjokerz
I'm not worried about carbon buildup. I get that they have both direct and port injection. My concern is engine longevity due to the added strain associated with DI.
Old Aug 20, 2021 | 11:05 AM
ibidu1's Avatar
ibidu1
I cant comment on 250k, but Im at almost 200k and aslong as you replace the water pump, change the oil every 3-4,000 miles, and other regular items these cars are solid, 2007-up GS350's ive seen a few at the 300k miles, pretty sure there gotta be some 400k runners by now.
Old Aug 26, 2021 | 09:23 AM
artfil91's Avatar
artfil91
2006 GS300 was direct-injection only and prone to carbon issues at higher mileage, 2007+GS350 has both direct and port injection helping to alleviate the carbon buildup.
Old Aug 26, 2021 | 09:39 AM
Lwerewolf's Avatar
Lwerewolf
No issues re: "strain".
More things to fail - yes.
More problematic overall - not really. If anything, the port (!) injectors tend to clog up on some models (hybrids)...
Old Aug 30, 2021 | 05:54 PM
R_Rated's Avatar
R_Rated
just rolled over 265k on my hybrid, nothing to report as of yet.
Old Sep 1, 2021 | 07:07 AM
LxSBase's Avatar
LxSBase
well mines is over 235,000 miles and I believe if you keep the maintenance up and watch out for that nasty timing cover oil leak they are pretty awesome. Did updrades: Amsoil engine oil/front diff/rear diff/ATF all from this company should boost ride and performance quality. I also installed x2 oil catch cams on mines. Oh make sure to use fuel system cleaner once a month to help with direct injection and that fuel pump thats on the crankcase. ✌🏽
contom
Jan 28, 2021 08:19 AM
cats899
GS F (2016-present)
17
May 31, 2017 02:02 PM
dat dude
Nov 23, 2016 08:12 AM
Infamous3
Nov 20, 2014 10:57 AM
DaveGS4
Aug 16, 2008 03:42 PM
