OK guys, can you tell me if this code requires new pdeal assy to correct?
Shop says "pedal force/load sensor switch fault.
IS a switch available? Shop says need whole pedal assy.
Please let me know your thoughts!
Have you inspected the throttle yourself its possible a plug came loose or something. If not a visual inspection would be good, and if you need to buy one, go for a used unit as these almost never fail. This is the first time I have ever heard of one failing.
www.car-part.com is a good search engine to search local junk yards, or you can find them on ebay. Just remove yours and look for the part number and just type that number into the search and you should see used units for sale.
THANKS Ibidu1 but I have no idea what to check, how to check. I told tech I never heard of one failing. He called Lexus dealer and they told him switch not available, have to buy pedal assy. Can you please contact me privately for additional dialogue.
