New TPMS sensors
Old Sep 10, 2024 | 07:38 PM
ibidu1's Avatar
ibidu1
Originally Posted by Blackedout14
Can you use any scan tool to reset the new sensors ?
You do not reset new sensors, you have to change the old serial number of each sensor. A good scan tool can allow you access to change the numbers. But if you already mounted new sensors in the tires, and didnt snap a pic of the serial numbers. Then you will need another tool to wave infront of each sensor, this tool reads the serial id of the sensors. Once you have those 4 different numbers, you can use the scan tool and log them in. Most cheap scan tools do not have access to tpms, if you do not have this. Probably best to take it to a big name tire shop, they should have the sensor read tool and a good scan tool to code the new sensors.
Old Dec 9, 2024 | 05:27 PM
WendyLex's Avatar
WendyLex
5th Gear
Can you set the threshold to zero? And just keep the sensors in your trunk?
Hubb23
Nov 5, 2023 11:54 AM
355F1
Feb 1, 2021 07:34 PM
rc0107
Jun 17, 2020 06:38 PM
brunp
Dec 17, 2017 06:47 AM
lexag12
Jun 14, 2016 08:35 AM
