Messed up changing tranny fluid
Old Jan 18, 2021 | 04:01 AM
KH818's Avatar
KH818
Originally Posted by ibidu1
All other gears were fine? try rechecking at the dip stick
Yeah but it sounds like the tranny is struggling now... maybe i didn’t put enough liquid ... i drove for 50 miles hopefully didnt do too much damage... guessing i need to put more? im about to toast my tranny
what do you mean by rechecking at the dip stick? put more fluid into the tranny? lol this is a problem :/
Old Jan 18, 2021 | 04:34 AM
ibidu1's Avatar
ibidu1
Take it to a toyota dealer and have them check it for you. Cheaper then toasting a transmission
Old Jan 18, 2021 | 04:54 AM
KH818's Avatar
KH818
i think i toasted my tranny... car won’t drive anymore not getting power to move car forward from transmission
Old Jan 18, 2021 | 05:01 AM
KH818's Avatar
KH818
Car is being towed lol. car wont accelerate but engine has power.... what a ****show.... oh well. I’m hoping it’s just low tranny fluid but i may damaged my tranny cause i drove it 50 miles
Old Jan 18, 2021 | 08:50 AM
KH818's Avatar
KH818
left car off for 2 hours somehow made it home... my coolant was leaking and i saw some coolant dripping down somewhere around my pulleys? anyone know what this is? water pump? my car was overheating on the drive home (got home before it really got hot)
any relation to me changing the transmission fluid and it probably being underfilled? not sure why else tranny would just not respond on the fwy after draining and filling
Old Jan 18, 2021 | 01:15 PM
PauloFR's Avatar
PauloFR
Ouch, this isn't a good sign for the transmission . It shouldn't have any relation to the transmission but your water pump seems to be on its way too.
Old Jan 18, 2021 | 02:11 PM
ibidu1's Avatar
ibidu1
Water pumps are cheap off of rockauto.com $90 bucks for an aisan brand. Man, this cars bad luck to you. I feel for your pain! Hopefully you bought this car really cheap
Old Jan 19, 2021 | 12:44 PM
CowBoE's Avatar
CowBoE
Did you check the trans fluid level using the dipstick? If so, how much is there?
Also, check for coolant hose leak, before concluding on the water pump.
Old Jan 19, 2021 | 07:18 PM
KevGS460ML's Avatar
KevGS460ML
Sorry to the OP that this happens to you, but...I have no idea why people keep on insisting on changing the tranny fluid when the owners manual clearly states that it lasts the life of the tranny. Mine's at 197k miles now, and I have never changed it once. Even if it breaks tomorrow, I made the correct decision because the tranny has lasted MUCH LONGER than its expected lifetime, which is 60k miles. And don't tell me if I had changed it, it would lasts even longer. I'd be happy for anything post 120k, which is 2x the warranty period, and mine is 2.5x that and still going strong (knock on wood). Keep this in mind the next guy who even thinks about changing out the tranny fluid.
Old Jan 19, 2021 | 10:54 PM
mspearl95's Avatar
mspearl95
if the expected lifetime of the tranny is 60k, I would say people are right to change the fluid if they go over that. Especially as the car ages.
Old Jan 19, 2021 | 11:26 PM
ibidu1's Avatar
ibidu1
Theres nothing special about the fluid toyota uses, nothing is lifetime! Toyota/lexus claim this so they can show there vehicles are easy on maintenance. That tactic sells more cars!
Drain and fills help keep fresher more lubricated fluids inside the transmission. If you are at 197k miles, it would be a good idea to drain a little bit at a time. Have the dealer do it if youre not comfortable with it. The same applies for your differentials
Old Jan 22, 2021 | 02:29 PM
KevGS460ML's Avatar
KevGS460ML
I have no intention on changing it because it’s a sealed system and I will let it be. As for the differential, it was definitely serviced as were other fluids. I am betting I’ll get another 100k out of it if don’t trade it in first.
Old Jan 23, 2021 | 01:54 AM
ibidu1's Avatar
ibidu1
Its not really "sealed" transmission theres a side fill port and a hidden dipstick inside the oil pan. The service department do offer transmission changes.
Being that our transmission are over built, they are after all almost identical to the toyota tundra transmission. So they do see less wear inside, but still all fluids degrade over time. They have a shelf life! Sure the transmission may or may not last 300k miles, but it would give you rougher shifts, and eventually start to slip when the clutches wear out.
Same thing with the engine oil changes, lexus claims 5,000-10,000 miles until you read the fine print. Then they recommend as low as 3,000 mile oil changes if you do a lot of stop and go driving. Its an advertisement pitch to sell cars, to make it appear the cars are trouble free and easier maintenance.
Old Jan 23, 2021 | 05:15 AM
KevGS460ML's Avatar
KevGS460ML
I once owned a Nissan 240SX, and it had high miles like 70k or so before I decided to replace the fluid. As soon as I have done so, it started slipping. It was the biggest regret in my life that I wished I had a time machine to roll it back. I brought it to several transmission shops, and they did the flush, but the problem persists. I came so close to getting a new one put in, then it mysteriously worked fine again. Since then, I vouched not to sway from the maintenance manual again, which for that car was to replace every 30k miles. For our car, it’s no change. Also, for mine it’s the same tranny as the LS460 not the Tundra.
Old Jan 23, 2021 | 03:33 PM
PauloFR's Avatar
PauloFR
Most Toyota transmissions won't slip if you drain and fill even at high mileage. But I admit it's a bit of a gamble after 40k miles.
