Power Lock and Keyless entry are now t working
Old Oct 27, 2020 | 12:22 PM
Hesham88's Avatar
Hesham88
Default Power Lock and Keyless entry are now t working
Hello all, a series of unfortunate events happened to my 06 gs300. Started with losing the power steering. Found the blown fuse and changed it. The new on got blown right away. A bigger fuse got the p/s to work but many things stopped working including the power lock and the keyless entry. Took the car to a service center, they found out that the wiring harness behind the dashboard is all burnt. They changed it and everything worked except for the power lock and the keyless entry.
they said that the steering lock actuator is bad and needs changing. I got them a used one, they say they failed to program it! Is there a way to fix this issue??
Old Nov 11, 2020 | 04:28 AM
Sky89line's Avatar
Sky89line
It could help you
Do you see the little small module on the right side with the square shaped? Remove the old one from your car and replace it to the new coulm you have got
Old Nov 11, 2020 | 05:44 AM
Hesham88's Avatar
Hesham88
Originally Posted by Sky89line
It could help you
Hi Sky89line, thanks for your reply. This is what I exactly got. I was told that the new module needs programming. The service center was not able to run this programming.
They said that the car doesn’t start when fitting the new module. I do not understand why!!
Old Nov 11, 2020 | 06:40 AM
Sky89line's Avatar
Sky89line
I have tried to program it but it didn't work out with me. So It's better to replace it with the old model you have. I think it has to do with the car security and keyless entry.
Old Nov 11, 2020 | 06:57 AM
Hesham88's Avatar
Hesham88
This is what they did. The old part is now fitted. But again, the keyless entry and the remote control are not working! So annoying
I’m not sure how is the steering module related to the door lock system!
Old Nov 11, 2020 | 07:08 AM
Sky89line's Avatar
Sky89line
Go to any car shop and ask them to do key programming. It's not that hard just connect obd2 and go to immobilizer function.
jrmckinley
Oct 27, 2020 12:28 PM
Sin1UZFE
Aug 15, 2020 09:11 PM
serjo7474
Aug 26, 2013 08:36 AM
DixonPai
Dec 28, 2010 11:16 AM
wahoo50
Oct 15, 2006 02:36 PM
