I need to take off the seat to replace the O2 sensor below. I disconnected the plugs but there is still a part of the harness attached to the seat preventing me to remove it. I wiggled it vigorously but it doesn't move. It isn't easy to see something in this area. Any ideas?
There is a plastic clip that holds the wires on seat harness. It will need a small screwdriver to unclip, but those wires are blocking the access... I did cut the tape around the wires, moved the seat out of the car and then detached the plastic clip...
Thank you! I tried to pry from different angles but I couldn't. At the end, I managed to slide off the tape from the plastic clip and remove the harness.
