Lexus GS 430 front window issue
Old Oct 26, 2019 | 03:29 AM
beminciu's Avatar
beminciu
Default Lexus GS 430 front window issue
Hi All,
Having the problem where front passenger's window is most likely not closing fully. Once going at the certain speed and increasing it - you can hear wind whining noise from the window top, if to click and hold on window button to close the window - wind sound disappears. Is the regulator somehow bad and is there a way to fix this window issue?
Old Oct 26, 2019 | 04:29 AM
ibidu1's Avatar
ibidu1
I would clean inside of the rubber tracks first and use a special lube. maybe dirt and grime or something is blocking it. Water, soap, and a tooth brush should help it out.
Old Nov 24, 2019 | 11:39 PM
beminciu's Avatar
beminciu
the cleaning handn't helped... maybe rubber seals need to be changed, but no visible issues on them..
tcr101
Nov 1, 2017 01:03 PM
Weidnera
May 25, 2017 01:54 AM
smm3
Mar 19, 2012 11:22 AM
durtysc300
Nov 17, 2008 09:41 AM
J_RoK
Jun 11, 2004 11:42 AM
